Old 07-11-2004, 02:28 PM
90 jdm 90 jdm is offline
bad wheel bearings?????????
i just put on new axles on my 90 hb and after about 100 miles i'm now strating to hear a grinding or howling noise coming from the front, it only makes the noise about 30mph and higher and gets louder as i speed up. i tighten the axle bolt cause it was loose and still makes the noise. could it be my wheel bearings or did i tighten the bolt too much???????
Old 07-11-2004, 02:46 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: bad wheel bearings?????????
could be wheel bearings or even your rotors if smells a little brake smell...most likely its wheel bearings, i dont think you can really over tighten the axle bolt cause i just put it on with impact wrench till it stops all the time....so just take of front wheels check out wheel bearings they scratch then there done with....maybe you get better info form somone else on here today
Old 07-11-2004, 03:07 PM
RedRex16 RedRex16 is offline
Send a message via AIM to RedRex16
The exact same thing happened to me. I got my drivers side cv axle replaced and not even two days later it started making noise at about 30 or 40 mph. Get it fixed as fast as you can because it only gets worse. I went to the place where i got my axle replaced and they quoted me 210 installed. which was bullshit so i got it done at my dads shop for like 50 dollars.
Old 07-11-2004, 06:36 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
sounds like a bad wheel bearing to me...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-11-2004, 06:51 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Ding, bad wheel bearing
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
