What is that site that shows the washer / bolt trick for camber?
There was a site that had detailed instructions / pictures on how to adjust the rear camber on the 6th generation Civic's using the longer bolts and adding washers.
Anyone got this link bookmarked? I really need it now ![]() Thanks!!
---------------------LX98Civic ---------------- nemesls_2000 ------- civickid77---------------- --- --- --- -- Sleeper in the middle -- --- --- ---
2000 BMW 323IT 1954 Ford F100 With every post my penis grows smaller Yakima Valley Truck Club Yakima Washington |
AF's Official Asshole RIP AUNIE |
![]() My question is: The guy says 1 washer per inch, so what about a 1.5" drop? ...I wonder if they make thinner washers that would work Thanks again!!
A curse upon you Oliver Cromwell You who raped our Motherland I hope you're rotting down in hell For the horrors that you sent To our misfortunate forefathers Whom you robbed of their birthright "To hell or Connaught" may you burn in hell tonight |
man thats tite, i wonder if anyone has tryed it to make sure it works good, and would this be bad for the car for any reason? i dont see why it would cause it looks resonble. Is the only thing we basicly doing is putting bigger washers on? cant we even use the old bolts to? if anyone did this please reply or pm me, cause i ruined my tires in freaken 10k miles and thats realy bad
stupid question but.....what does doing this do? save tread if you lowered yer car? makes tires level? dont hate me cause im ignorant.
I know a guy who did this to his civic about a week ago. I don't see how this would cause any problems with the car.
why would you need new bolts though? wouldnt you just need new washers? or is it just a good idea to get new stuff while doing this?
You just don't want the bolts to be too long. I may check out another Home Depot to see if I can find the 45mm. Oh and the 50mm's I got..... Only 3, all the f**kers had ![]() The guy at Home Depot also said to check Ace Hardware out. May stop by there as well
And the reason you need the longer bolts is because you are sticking washers in there and spacing it out, which means the threads are not inserted as much and I would imagine you go too far, presto bolt rips out and so does your back end
Exactly, you need the extra length on the bolts to accomadate the new washers, the original ones won't be long enough. And the reason you're doing this is to correct too much negative camber, which can cause uneven tyre wear. Check the FAQ for more info on this!
It shows a picture of the ingalls camber kit. Its basically the same setup. The old bolts are not long enough to do this. So you need to either buy the kit or get new bolts & washers. |
