Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-11-2004, 01:34 PM
Yoxy99 Yoxy99 is offline
Unhappy Vibrating After 65 MPH
I have a 1994 Buick century the model with the 2.2 L ,4 CYL Engine and it seems that everytime I drive on the highway once I hit 65 MPH the car seems to shake a vibrate and its pretty annoying feeling but it only happens after 65 MPH I was wondering if anyone might know what the problem is and the solution to it. Thank you and anyone who can help i would greatly appreciate it.
Old 07-11-2004, 04:54 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Vibrating After 65 MPH
Make sure your tires are in balance. You might have lost a weight off one of the wheels. Most vibrations of this type will occur from some rotating mass in the drivetrain.
Another possibility is CV joing going bad. Although I would believe you would hear something or feel changes in the car other than just a vibration in at 65 MPH if it were a CV Joint.
Old 07-11-2004, 07:13 PM
Would rotating the tires help or just getting them weighted and balanced out?
Old 07-11-2004, 08:39 PM
public's Avatar
public public is offline
Rebalance your tires.
Old 09-30-2004, 09:05 PM
northwichita northwichita is offline
vibration
A loose inner or outer tie rod joint will cause vibration at speeds,and should be checked for asap.
Old 10-02-2004, 01:57 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
so would a bad hub bearing or a warped brake rotor.
Old 10-02-2004, 03:52 PM
public's Avatar
A warped brake rotor will not usually cause this. Here in good ole Florida everybody has warped rotors due to the rain every afternoon. No one has vibration problems at speed. Just surging when stopping and pain in the wallet from the frequent replacement.
And a bad hub bearing will make a lot of noise.
Old 11-23-2004, 12:27 PM
stoned_pimp420 stoned_pimp420 is offline
Send a message via Yahoo to stoned_pimp420
It might be like mine was. My rear rims were warped and it sounds like yours are too. You better get those checked out because it WILL DESTROY a wheel bearing.
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
Old 12-02-2004, 12:24 AM
sky2k4's Avatar
sky2k4 sky2k4 is offline
Send a message via MSN to sky2k4 Send a message via Yahoo to sky2k4
Same prob here fixed heres how
I git my tires Rebalanced and two new tires on the fron
works fine now and at 85-90 flyies right thrue ,Weeeeeeeee sad but true!
Old 12-02-2004, 03:20 PM
public's Avatar
Cool.
Yes, I am retarded.
Old 12-02-2004, 04:04 PM
bignoisey bignoisey is offline
Now he'll get a speeding ticket since his overspeed alarm is gone.
