Old 07-11-2004, 11:51 AM
tashashepherd823 tashashepherd823 is offline
Send a message via Yahoo to tashashepherd823
Unhappy Power Window on 2002
My passenger side power window motor went out on me the other day and I bought another one but I don't know how to put it in correctly. Could someone please, please help me with some instructions.
Old 08-02-2004, 11:46 PM
Ethan504 Ethan504 is offline
Re: Power Window on 2002
well u have to take off the panel and MAY have to take a grinder and cut out a hole on the metal around the motor...cuz it dont come off, then connect everything from the old to new motor
Old 08-03-2004, 07:06 PM
5150cavy 5150cavy is offline
Send a message via AIM to 5150cavy
I work at a chevy dealer and replaceing the motor urself it isn't that hard if u don't want to cut ur doors u can just cut the rivets out that hold the regultor in place(there is only 4) and remove the motor and regulator as one. U can get new rivets and the gun to install them at any hardware store or u can buy some nuts and bolts to replace them with, just get locking nuts so they don't come apart. It's alot better and u don't have to worry about fucking up ur door.
Here is gm's procdure for removing this.
1.Lower the window to the three quarters down position.
2.Remove the door trim panel.
3.Remove the water deflector in order to access the window regulator.
4.Remove the window to regulator nuts.
5.Push the window to the closed position and tape in place.
6.Disconne the regulator electrical connector.
7.Remove the power window regulator bolts.
8.Drill out the power window regulator rivets.
9.Remove the power window regulator from the door.
If u email me i can try and get u some pics of where everything is at or if u have any other question's feel free to ask.
You can check out my ride and my crew at http://www.twistedperfektionz.com
UNDER CONSTRUCTION
