Old 07-11-2004, 03:31 AM
tds715 tds715 is offline
Send a message via AIM to tds715
100 shot
what up grades do think i should do to run a 100 shot.
94 accord in works h23 turbo full body kit and bit of shaving and new paint
88 gt 5.0 just gettin started
Old 07-11-2004, 04:34 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: 100 shot
255lph fuel pump- approx $100
Kirban AFPR- approx $65
That should do it.
Old 07-11-2004, 08:52 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: 100 shot
I'm not sure how your car will handle N2O. Unless you have converted to mass. Atleast I'm assuming with as touchy as speed density is, it wouldnt handle N2O very well.
Old 07-11-2004, 10:44 AM
eillob's Avatar
eillob eillob is offline
Re: 100 shot
I think 255lph is a little overkill unless you see a large supercharger and heavy injectors in your future. My recommendation is a 190lph.
I would also recommend working on your exhaust. Nitrous is going to stuff more air in the combustion chamber so you need to have a way of getting rid of it.
I would suggest a single or two step colder plug to help prevent detonation like an autolite 24. And an aftermarket ignition like crane or MSD wouldn't hurt either.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
