Go Back   Automotive Forums Car Chat > Subaru > Legacy / Liberty / Baja
Old 07-11-2004, 01:08 AM
tothetune tothetune is offline
2 cylinders out?
Very rough idle. New plugs and wires. When I pull either of the 2 plug wires for the right side of the engine, hardly any change in performance. The plugs and wires are good. Is it possible the timing belt jumped a couple teeth on the right side sprocket? Why would both cylinders be unresponsive like that?
Old 07-11-2004, 01:13 PM
2 cylinders out?
Did a compression test, both sides read 150. Stethoscope tick on all the injectors. Every wire getting a spark. Can't figure this one out.
Old 07-11-2004, 04:24 PM
Will2 Will2 is offline
Re: 2 cylinders out?
Burnt valves?
Old 07-21-2004, 12:26 AM
JigokuZ JigokuZ is offline
Send a message via AIM to JigokuZ
Do a vacuum test...
Old 08-26-2004, 09:16 AM
memecode memecode is offline
Send a message via Yahoo to memecode
I had this on my '96 GT a few months ago, and we eventually got to the bottom of it. It was the fuel pump dying.
The fuel pump was only pushing enough pressure to feed the 2 cylinders nearest the pump. The other 2 weren't working, and fouling the spark plugs.
We also had the air flow meter go on us at the same time, so it was bloody hard to untangle all the symptoms... we had a very sick car for a while.
So, new fuel pump and it's roaring along again.
Old 08-31-2004, 04:07 PM
G-Force G-Force is offline
Just had this happen to my Eagle Talon Turbo. It turned out that the Cam Location Sensor went bad. If there is no spark at all to those 2 cyl. it could be a crank or cam location sensor. Check the trouble codes to begin with. Bring to shop if you can't check the codes yourself.
