Car Died
well today when i got to work, after parking i put it in reverse to back up a little and right when i gave it gas it died on me
. now it wont start back up. it turns over and everything just not gettin spark. i got new cap and rotor (didnt help). i also checked fuel filter cause i thought maybe it wasnt gettin fuel but it is. rotor is spinning and i know dizzy is getting spark. check engine light didnt even come on.besides wires and spark plugs, what else should i check?
91 Hatch SI Heart of my Baby - DOHC ZC - Si tranny - PG7 Finally painted!!!
Re: Car Died
timing belt
Check the coil and the igniter
where is the igniter located at?
how do i check for spark?
Re: Car Died
"hi! my name is Lady, and i'm a HONDA-holic" ..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose! ![]() *~ I <3 the G Ride ~*~ I <3 OLD SKooL |
thnx. tommorow im gonna check ignitor,coil , main relay (gotta find out how to do so) and see if it is sparking. sorry if it sounds stupid but i pull spark plug out, hold it on valve cover and have someone crank engine while i look for spark, correct?
here is their way to test: Coil replacement: info pulled from: http://www.binghamtonlife.com/manual...electrical.htm there you have it folks
Thanks very much. 1 more question. how you check main relay?
Re: Car Died
look in the manual, the link i left. my brain is fried tonight...i'm sure you'll find it quicker than i
Re: Car Died
uh mine died a lil ago and it was the battery, and if thats not it ure sprk plugs could be outta order...
Currently trying to piece together a Turbo CrVtec bubble hatch, expecting sumthin like 500hp?!?!?! |
ok. today i changed spark splugs and tested igniter. when i pulled old spark plugs out they smelt like fuel. when testing igniter i tested the white/ black n yellow/ white n blue/ and blue wires with light tester with ignition switch on. black n yellow/white n blue were the only ones with current. blue wire = nutting and white wire makes a popping sound when touched . says all wires should have continuity voltage. what you all think?
Not sure about the electrical stuff, but the spark plugs smelling like fuel should be normal since you were feeding it fuel with no spark.
If it helps any I had the same problem and I got the coil and ignitor replaced. Turned out the ignitor was the problem I think, but after they were replaced the car ran fine. |
how much are coil/igniter?
Re: Car Died
How could the problem be from the wires being in the incorrect order when the car was running moments before this happened? Just curious.
