Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 07-10-2004, 11:54 PM
robberger16 robberger16 is offline
Send a message via ICQ to robberger16 Send a message via MSN to robberger16
Aussie 944 owner with big probs
G'day folks, iv had a look over the posts here, but i have a few questions about my car, a early model 1985 944, bout 130,000miles
1, heat come from lots of places, when the heater is off, it comes from under the dash, and from the where the gear stick is(auto) how do i stop it
2. My sunroof goes up no problems.. and it goes down fine, but the brackets at the back, wont move from side to side, so i can detach the whole thing, i know im meant to have the key in the 2nd position(just before accessory), but does nothing, is this easy fixable??
3. i am 90% sure its a head gasket, and not a head cracked, but i have oil in the water, i need to get the car to a repair store, 70miles away.. can i drive, or is that just really risking it
Heh, if its cracked head, then im gunna be outta cash for ever :'(
thanks for any help people
Old 07-11-2004, 11:02 AM
930guy 930guy is offline
Re: Aussie 944 owner with big probs
Check your oil cooler seals first before you jump into your head gasket
Old 07-12-2004, 08:35 PM
83-944 83-944 is offline
1) there should be two boots (there are on manuals) at the gearshift lever. Most likely the inner rubber boot has cracked and probably needs replacing. This problem can be amplified by exhaust leaks so you may want to check that out as well.
3) Headgasket leaking: doesn't that mostly give you smoke out your exhaust? I'm with 930guy on the oil cooler seals. You can drive it there, but you'll need to flush the oil and water out of the engine. Don't just keep on driving it. Oil pressure may be higher while the engine is running forcing the oil into the water but once the engine is shut off, the opposite happens. water will still hold pressure and leak into the oil. NOT COOL! Pun intended.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
