Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 07-10-2004, 09:50 PM
Gebo Gebo is offline
Overheating at idle 90% of time
I have a 92 Transport with 189,000 miles. Just did radiator flush an' fill and replaced thermostat. On hot days while idling, the temp gauge will go to the last yellow line before the red. I know the fan comes on because I have checked it. When I get back on the highway, it will run around 200 or so. IF it is cool outside, no problem. What should I do?
Old 07-10-2004, 10:42 PM
joeval joeval is offline
Re: Overheating at idle 90% of time
First make sure the fan is spinning with enough force and it stays on. Then check the circulation. Your water pump may be getting weak and needs replacement.
Old 07-11-2004, 06:44 AM
Re: Re: Overheating at idle 90% of time
Exactly how do I check the circulation???
Old 07-12-2004, 11:47 AM
Depends how it looks like. I normally have the radiator cap open and let the vehicle warm up. Once it's warm (thermostat is open) you should be able to see the water circulate and circulate faster when you give it gas. If you don't see it circulate, or circulates on and off, then your pump is going bad.
Old 07-12-2004, 12:45 PM
llerrad llerrad is offline
How old is the rad in this van? Could be galleries clogged and flush will not clean it out. Might be time for new rad.
Old 07-12-2004, 09:14 PM
But it only "overheats" at idle at high outdoor temps, like over 85 f. It runs at 200-210 degrees at highway speeds in hot outside weather. It has had a rad replacement at least once in the last 6 years.
Old 07-13-2004, 07:12 PM
LMP's Avatar
LMP LMP is offline
In 40 years + of mechanics, I've never seen a pump failure other that when it started leaking fluid out through the bearing, or bearing failure accompanied with horrendous noise. I've never seen a car pump impeller damaged in a way that water circulation would be compromized.. AM I really lucky? However, I've seen numerous water circulation thermostats that would block in the closed or partially closed position, clogged radiators even when they do not seem to be clogged, and thermostat switch that would not switch the electric fan on - but on the transport (mine is 3.8 '93), it is controlled through the ECM.
So once you have cured your overheating problem, please tell me so I adjust my statistics.
Bye
Old 07-13-2004, 07:17 PM
LMP's Avatar
LMP LMP is offline
In fact, if I had your problem, I'd try first removing the thermostat. Cost nothing, and results show fast. If problem resolves, then install new thermostat.
Old 07-13-2004, 08:51 PM
LMP,
It is not the thermostat. I replaced it and still same results. Did you notice that it is intermittment? My fan comes on at 230 according to my dash gauge. ANy other suggestions?
Old 07-15-2004, 07:10 PM
Since it is intermittent, I would think it's the fan. You say it does turn on but you need to check when it overheats to see if it stays on. And I have replaced water pumps even though it was not leaking. And that was the problem.
Old 07-23-2004, 03:53 PM
Where is the switch that controls the fan coming on at 230 degrees?
Old 07-23-2004, 04:27 PM
LMP's Avatar
LMP LMP is offline
No switch: the fan is controlled through a relay directly from the computer (known as Powertrain COntrol Module (PCM) with 3.8, Electronic control module ECM with 3.1) that reads the temperature from the coolant temperature sensor. So it is the computer's decision that turns the fan on. There is one single coolant temperature sensor that serves the gauge directly and also feeds information to the computer.
NOw the relay itself may be the culprit: in fact there are 2: one for pusher fan , one for puller fan. They are located RH side of engine compartment, behind composite headlamp.
Old 07-23-2004, 07:45 PM
LMP,
I believe I have a problem with the puller fan. As a matter of fact, I didn't know I had one 'til today. I got it up to temp (200 or so) then let it idle with the a/c on. the pusher fan ran. I then turned the AC off and in about 30 seconds or so, the pusher fan shut off. I kept it idling until the temp got to 230 and the ac fan came on again. The puller fan never came on. Now what?
Old 07-23-2004, 09:17 PM
LMP,
I went looking and I can't seem to find the relay.
Old 07-23-2004, 09:38 PM
LMP's Avatar
LMP LMP is offline
There are several relays - 4 in fact, - located behind framework behind composite headlamp (passenger side).
Counting from radiator toward the passenger side fender, there are:
-a/c compressor relay
-coolant puller fan relay
-fuel pump relay
-coolant pusher fan relay
-one more relay position that shows empty on my picture.
mmm...and they say relays may not be indexed on mounting rail in order shown...!! However, the first three in list above are fed by wires coming from a common bundle while the pusher fan wiring has a separate harness.
I may scan the picture I have here and send it to your e-mail.
(this is ,93 service manual but this is similar to 92)
