Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-10-2004, 07:37 PM
zimonwheels zimonwheels is offline
can u clean egr valve?
Hi, is it possible to clean a sticking egr valve? If so what kind of solvent would be suitable. I drive a 97 sl2 with a linear egr valve. thanks in advance
Old 07-11-2004, 12:01 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: can u clean egr valve?
yes you can, just take the off the two 10mm bolts, spray some regular good old carb/choke cleaner in there and wipe all the junk off, maybe spray a little in the passiges in the head. if its real bad, some people (including me), will take a small screwdriver or whatever and really rip the carbon out. weather or not the little valve can move easilly by hand is really the only why to tell when you're done. when you put the EGR back on, you may or may not need a new gasket, get one from your dealership just in case, its about $5.
Old 07-22-2004, 01:22 PM
BboyFlipRoc BboyFlipRoc is offline
So, that means I can also clean mine as well... Being I hnave a 98 Saturn SL... I just got the gastket like two days ago. And I have insufficient flow so the SES light has been going on and off...
Old 07-22-2004, 01:43 PM
mik13usa's Avatar
mik13usa mik13usa is offline
check the vacuum lines and all the passages, they may need to be cleaned and or replaced as well!
Old 10-08-2004, 11:13 AM
dw97sc1 dw97sc1 is offline
Send a message via AIM to dw97sc1 Send a message via MSN to dw97sc1
The part you wanna break loose is called the pintle. Looks like a little torx screw on the bottom of the EGR. Is is supposed to go up and down. Carb cleaner will break it loose.
