Old 07-10-2004, 07:27 PM
Skateforfood's Avatar
Skateforfood Skateforfood is offline
Paint problem?
Hey, I had one of my first problems in a year today.I just painted my Escalade. After a few coats I notice that the red paint didnt go in the Panel lines and door cracks. What did I do wrong? Maby mike you would know this?Or maby I should start searching again for another hour.
Old 07-10-2004, 07:39 PM
primera man's Avatar
"P-Man"
Re: Paint problem?
Did you use primer and how long did you wait between coats?
Sometimes when applied to thick and to soon after another coat the paint has trouble "sticking" to these places.
Allow longer time between coats so it gives the paint enough time to dry and also very light mist coats works better untill you can apply a "wet" coat
View All My Models Here.
Old 07-10-2004, 07:43 PM
Thanks that did help tommorow Ill put a mist coat on it.
Old 07-10-2004, 07:59 PM
Vric's Avatar
Vric Vric is offline
Re: Paint problem?
when paint don't go in panel line (or panel line are brigher than the car) it's becose your coat is too thick
Old 07-11-2004, 03:30 PM
tonioseven's Avatar
Re: Paint problem?
Also, did you wash the model with a soft toothbrush and some dish soap before you primed it?
Old 07-11-2004, 05:57 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Paint problem?
What kind of primer did you use? If you used a regular old can of primer from Wally-World or Duplicolor its most likely an enamel primer. Often times the base coat is an acrylic-lacquer instead. The problem being that enamel cringes and shrinks (more than normal) when an acrylic-lacquer, or any lacquer for that matter, is applied over the paint.
Please list the paints you used.
-Mike
