Old 07-10-2004, 05:17 PM
JMacDonald JMacDonald is offline
Send a message via AIM to JMacDonald
Camaro rear end interchange?
Im building a 67 camaro right now, but it only has a ten bolt rear end in it which definitely isn't going to be strong enough with the tourque my engine will be producing. Does anyone out there know what other types of cars might be able to just swap a 12 bolt without having to make major adjustments or any at all. I used to be a ford guy, but Ive switched over to the dark side, hopefully someone on here can help me out, thanks alot.
John MacDonald
Old 07-10-2004, 05:38 PM
Dober89 Dober89 is offline
Re: Camaro rear end interchange?
I dont know what other vehicles would be a direct swap. Unless you were to find a 12 bolt rearend from another camaro. If youve got the cash you could always go with an aftermarket 12 bolt or 9 " rearend that would be a direct fit.
Old 07-10-2004, 06:36 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
your only direct swaps are from first gen camaros and 68-71 novas.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 07-10-2004, 11:42 PM
Re: Re: Camaro rear end interchange?
Does first generation Camaros only include 67-69?
Old 07-10-2004, 11:43 PM
Yeah, thats one of my options....but those aftermarket rear ends are so damn expensive, its definitely one of my options, but more like a last resort
Old 07-10-2004, 11:44 PM
Yep those are the years for 1st generation.
Old 07-11-2004, 01:18 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
i've seen some companys that will make a custom ford 9" rear end for about $500. this is just the housing, no axles or differential included and is custom fabbed to bolt right in. then you could get the differential and axles off ebay for a few hundred. a ford 9" will hold up to about anything you can throw at it
Old 07-11-2004, 02:00 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
what if I throw a grenade at it?
Old 07-11-2004, 02:02 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
John MacDonald
What 10 bolt is it? is it the 10 bolt 7.5 ring gear or the 10 Bolt 8.5 ring gear???? if it is the 8.5 10 bolt, you will have no problem at all my friend.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-11-2004, 02:04 AM
Genopsyde's Avatar
The President
how come that post wasn't as alcohol effected as the ones in the other thread?
Old 07-11-2004, 02:47 AM
Hypsi87's Avatar
Tryy ing to acte sopber .... not working thogh.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
CORE402's Avatar
CORE402 CORE402 is offline
I am sure it is a 7.5" ring gear 10 bolt. The corporate 10 bolts didn't come out till the 70's. But you could also expand your choice of rear ends to the corporate 10 bolts if you want to stay cheap, but I doubt they will just fit right in.
Old 07-11-2004, 04:00 AM
no if its stock it would be the 8.2.
humm, i gather someone had a good night tonight.
<<my engine
