Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 07-10-2004, 05:55 PM
josh12376 josh12376 is offline
body kits and repair
two things one i can not find a body kit for the 85 crx any where except andys auto is there and other year and make that will fit with or with out alot of extra work some is ok just not alot. second i have 4 holes in the floor board in this car what would be the best way to fix them. is it possible to replace the whole pan or just section of it easily. of course the holes are both front corners and both rear corner. it lloks like they weld part of it and caulk the rest but not for sure
Old 07-15-2004, 07:02 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: body kits and repair
Check with ectremedimensions.com
http://www.extremedimensions.com/sho...pe=Body%20Kits
housemanautosport.com
http://www.housemanautosport.com/newproducts.html
Or Ebay.
There are no other body kits that will work without modification. To fix your holes you can just weld in patch pieces without replacing the whole pan.
