Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-10-2004, 03:36 PM
daveycarpet daveycarpet is offline
Transmission Problem
Hi All......We've noticed lately with our 2000 Montana that when going up a hill and when it downshifts it feels like we are going over a wash board.
It does'nt shift down right away. When it has down shifted then it smooths out again.
Any ideas as to what the problem may be?
Awaiting your replys, with many THANKS.
davey carpet
Old 07-11-2004, 07:24 PM
nick0750's Avatar
nick0750 nick0750 is offline
Re: Transmission Problem
you should bring to a dealer , has the check engine light come on? if it has any code stored should help diagnose the problem, i have seen a few lately that needed a few internal trans solenoids and possible valve body, have it checked.
Old 07-12-2004, 04:50 PM
umina umina is offline
I agree, sounds like you've got problems. These seem to be the same tranny problems everyone has reported with the Montana/venture/silouette. Probably a valve body. I saw you can get them rebuilt on Ebay for like 300 bucks. I believe (don't take my word on this without looking at the shop manual) the valve body on this tranny just bolts on after you take the pan and filter off from the bottom.
Old 07-12-2004, 11:52 PM
Thanks guys for your reply's to my post.
Will see what I can do to rectify the problem, will take your suggestions into consideration.
We have just had our plugs changed and the problem showed up after the new plugs were put in, so it may be related.
Will post when we have found and fixed the problem.
Thanks again
Davey Carpet
Old 07-26-2004, 11:29 PM
mrdctaylor mrdctaylor is offline
Any fix for this?
Old 07-28-2004, 01:37 PM
DamienZ28's Avatar
DamienZ28 DamienZ28 is offline
Ack now I think about it mine is starting to do this also.. A small shutter during the shift 80k plus miles 1999 van Any definite fix yet?
http://www.fiawtcc.com/
2006 BMW 330i| 2009 Mercury Mariner Premier
Old 08-01-2004, 11:16 AM
Since our problem started the code mentioned it was the EGR valve stuck in the open position.
Clean or replace?
Mechanic on holidays, waiting his return
Davey Carpet
Old 08-02-2004, 09:00 AM
tmorris1 tmorris1 is offline
I had this problem under warranty. It was fixed by replacing the valve body. Anytime you would give it a little gas or hit a slight incline the torque converter would unlock (which feels like a downshift). I think some of the valving in the valve body leaks and bleeds off pressure which causes the torque converter to unlock.
Old 08-18-2004, 07:48 AM
FYI...
Well, the transmission shop got it to throw a code--and it wasn't the transmission. It was a cylinder mis-fire. I took it back to my mechanic and he replaced the plugs and wires. That took care of the problem! Whoo hoo!
