Old 07-10-2004, 03:00 PM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
I learned something today...
I did a quick install yesterday, put my blaupunkt components into my 96 accord. I mounted the new tweeters inside the door piller (behind the power mirror on the plastic 'triangle').. I hooked it all up, put it all back together and ran it for a while until my pioneer GM480 started going into protect mode over and over (you know, the clipping off like it's shorting a speaker wire). I thought "Surely to god I didn't blow my new speakers" so I started pulling it apart... my brother had to point out the fact that my factory components (which WERE blown, by the way) were probably still hooked up in their dash mounted location, still in line with the harness (which I tapped into behind the head unit with the amp).... so yes, not only was the Amp seeing a funky load, but it was trying to push through blown speakers (most likely a dead short)... it's all good again, I'm retarded, learn from my mistakes.
Old 07-10-2004, 03:54 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: I learned something today...
lol o man.. hey do u have any pics of your tweeter install.. i want to do it.. so yea.. any pics thx
Old 07-10-2004, 04:57 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
an easy mistake to make, especially if you use any of the factory wiring.
Old 07-10-2004, 05:08 PM
<nod> I was going to run fresh wiring straight from the amp into the doors but MY GOD, the 'grommets' are a pain to get to, I tried for an hour to find a way to poke a wire from the kickpanel into the door through the grommet tube.. <shrug> only running 80 watts per channel, I figure the factory wire (in spite of the splices) will be sufficient... the system sounds pretty damned clean to me at this point. I need to get an RTA in there and flatten the curve soon.
Thuggie, I'll get some pics up as soon as possible..
Old 07-10-2004, 05:18 PM
Here you go.
http://users.mikrotec.com/djbrady1/speaker1.jpg
http://users.mikrotec.com/djbrady1/speaker2.jpg
http://users.mikrotec.com/djbrady1/speaker3.jpg
http://users.mikrotec.com/djbrady1/speaker4.jpg
http://users.mikrotec.com/djbrady1/speaker5.jpg
http://users.mikrotec.com/djbrady1/speaker6.jpg
Basically, I popped the plastic piece off, drilled a small mounting hole in the plastic (the backside of the tweeter has a threaded hole) and mounted the tweeter to the plastic with a small screw provided with the speakers.
