Old 07-10-2004, 01:46 PM
AnDY_86 AnDY_86 is offline
Unhappy is there cold air...
I own a 1991 ga w/ 2.3 ho 5spd and i was wanting to put cold air on but i haven't found anything. i tried quad4forums.com found nothing but stuff that i will get later. I thought about looking for cold air sor the 2.4's and put it on my 2.3ho but i don't think it will work. what can i do?
Old 07-21-2004, 11:38 PM
redhot97GAGT redhot97GAGT is offline
Re: is there cold air...
Build your own. That's what I did. Buy a WAI and add a steel flex tube. It'll cost you half the money and you get your CAI!
Old 07-22-2004, 09:05 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
pvc pipe works nicer than steel tubing cus the plastic doesnt heat the incomming air as much only problem is you gotta make precise cuts and mesurements and elbows can be tricky. Make sure the element is out of the engine bay or is shielded from the engine heat to make the cai work better.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 07-22-2004, 02:13 PM
I've heard alot of bad thing about pvc in an engine compartment.I like the steel tubing because you don't have to cut it also the tube i got was spiral I understand that its supposed to be good for reduced turbulance.
