Old 07-10-2004, 12:33 PM
mcsd mcsd is offline
Instrument panel
I have a 98 caravan with a dead instrument panel. From other messages it looks like I have a bad bcm. Once I get it fixed I'll post the results, maybe it will help someone else.
Old 09-12-2004, 03:31 PM
johnc9999 johnc9999 is offline
Re: Instrument panel
Our 99 caravan's instruments just died. Did you solve the problem with yours?
Old 09-17-2004, 03:13 PM
No, I have not solved my problem yet. It's intermittent. However, If I hit the dashboard just above and to the left of the radio, the panel comes on
Old 09-17-2004, 05:48 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
You're joking, right?
If not, pull the cluster out and look for a loose connector to the back of it. You only have to remove the lower plastic tray in front of the cluster, plus the two screws that attach it to the top .
Old 09-19-2004, 07:53 PM
Instrument Cluster Problem Solved
Just to complete this story... The day after I posted this question, the car did not start. Our friend gave us a jump, and the cluster came back to life. We had the battery terminals cleaned and we've had no more problems. I suspect that the system just wasn't getting enough juice to work properly.
Old 09-29-2004, 11:26 AM
jmcadams68 jmcadams68 is offline
My wife's cluster went out last week on a 96 Caravan. After reading some of the replies, I cleaned the battery terminals and the cluster started working again. Thanks.
Old 09-30-2004, 08:19 PM
vipergg vipergg is offline
Re: Instrument Cluster Problem Solved
The clusters get hung up for some reason , like a computer getting frozen and you have to reboot as an analogy . The fix in a lot cases is to just pull the IOD fuse for about 10 seconds and then reinsert and this will fix it in a lot of cases .
Old 10-04-2004, 03:49 PM
sixseas's Avatar
sixseas sixseas is offline
It may be possible if there is a voltage drop large enough a diode in the cluster may shut down if it happens again measure voltage to the cluster an insturment cluster would run on the few amps in 8 AA batteries so any shutdown would likely be voltage driven.
If I may ask a question, does anyone have suggestions in an intermitant cutout of digital cluster. It goes blank or blinks but dash light circuit stays on. Dealer did expensive traced with no luck. Have double check connectors wiring voltages etc. without success. Wanted to switch out the cluster with another I can get to isolate problem but the dealer warned insturment cluster and ECM must be switched in pairs or will rewrite the new mileage. I have 75k miles and replacement has 160k they wants $325 to reprogram must be done before they wont do if mileage is lost. Any suggestions?
