Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-28-2002, 09:08 PM
bradboy bradboy is offline
low power output with turbo setup
I recently installed a custom turbo system on my stock H22a1 but I am convinced my car had more power at higher rpms (5000+) as normally aspirated than with the turbo. I hit full boost(8psi) @ 3000rpms and the car pulls pretty good to just about 5000. Then the power/torque stops rising, and there is a gradual climb to redline. Evenwith this lack of power the boost does not fall much. I first thought it was lack of fuel, and installed additional injectors and controller but this did not help much.
I use a turbonetics t3/t4 turbo (housing's a/r uncertain)
I it possible that the turbine housing could be restricting the exhaust flow too much?
93 Prelude Vtec-Turbo
Old 01-28-2002, 09:17 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
You read 8psi and think you're not getting as much power as you were at zero boost!?!? Something is seriously wrong.
Where do you have VTEC engagement?
Do you have an A/F gauge?
Have you read your plugs after a high-RPM run?
Anybody have a dyno & wideband O2 sensor you can get to?
Old 01-28-2002, 09:28 PM
cybercrx00 cybercrx00 is offline
Send a message via AIM to cybercrx00 Send a message via Yahoo to cybercrx00
where are you located bradboy?
Old 01-28-2002, 11:53 PM
pvang31019 pvang31019 is offline
you might have a too small of a turbine housing for your motor size....
maybe it's a .48 a/r way too small...you know the size of the wheel?
try a .63 a/r housing...you can buy it from turbonetics or garret. If you need one, let me know, I can get brand new garret sh*t for cheap...
Old 01-29-2002, 12:22 AM
Someguy Someguy is offline
Send a message via AIM to Someguy
Yeah somethings wrong. Unless its horribly too small of a turbo, in which case you wouldn't be making boost in the high end, won't loose power over NA. I think I would hit a dyno and do some tuning.
Old 01-31-2002, 07:59 AM
Re: Turbonetics t3/t4/ turbo size on H22A
Does a stage 3 turbine provide more free flow of exhaust than the lower stages, or is it the other way around. Is .57 trim compressor reasonabe size size for this engine.
Old 01-31-2002, 09:50 AM
Atten. Fritz
Re: Your questions for original post.
Where do you have VTEC engagement? = Tried many points from 5000 - 7000
Do you have an A/F gauge? = Yes -normally stays @ high abmber & mid green
Have you read your plugs after a high-RPM run? = very dark brown colour
Anybody have a dyno & wideband O2 sensor you can get to? = No- Closest one is a few hundred miles overseas.
Old 01-31-2002, 04:45 PM
yes, the stage3 provides more flow, but slightly more lag.
a .57 trim compressor is fine for that motor, what I'm concerned about with that turbo is that the turbine housing is too small...
Old 02-01-2002, 06:49 AM
Atten. pvang31019
What turbine housing do you recommend ?
Old 02-01-2002, 03:27 PM
Re: Atten. pvang31019
at least a .63 a/r
My ls/vtec and my cousin's h22 both have .82 a/r housings and a 60-1 compressor housing...
Old 02-05-2002, 06:48 AM
Re: low power output with turbo setup
PROBLEM SOLVED - I installed a different version t3/t4 which has larger turbine wheel & housing. The car now has a bit more lag but makes good power to redline
Old 02-05-2002, 02:23 PM
Re: Re: low power output with turbo setup
see, didn't I say so? good ups bro
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
