Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-10-2004, 10:58 AM
greendayhbt26 greendayhbt26 is offline
Send a message via AIM to greendayhbt26
Question s-10 back up lights
my back up lights dont go on when i put my truck in reverse, the fuses, blubs etc are fine. any suggestions?
Old 07-11-2004, 07:33 AM
Dan24 Dan24 is offline
Re: s-10 back up lights
I have the same problem, I have been told that it could be wiring or something in the shifter that turns the light on. I yours auto or manual transmission? Mine is manual and a 1996.
Old 07-11-2004, 07:52 AM
smokey041369 smokey041369 is offline
there's a set of wires that plug into the trans check that connection for corrosion and clean if that dosen't solve the problem then it's a bad reverse switch
Old 07-11-2004, 10:50 AM
where are these wires located exactly on the transmission..
and its a 98 manual
Old 07-12-2004, 06:20 PM
E_C_M-town E_C_M-town is offline
on the passenger side on the tail shaft. there are two plugs, one for your speed sensor, and one for your lights. sadly the switch is located inside the tranny. if it is not the plug, i would just get a good flashlight. it is not worth the trouble to take it apart.
Old 07-12-2004, 08:18 PM
lol i cant use a flashlight, in new york state i need them to be working in order to apss inspection
Old 07-12-2004, 08:31 PM
one more question....i looked under my car at the tranny and i noticed 2 wires on the passenger side on the end close to the engine. is the tail shaft the end nead the driveshaft, or the engine?
Old 07-12-2004, 10:41 PM
driveshaft end. but if you notice there are two wires, i'm not sure right off hand which one it is, but the other is for your speedo. it won't hurt anything if you just checked it out while you are there. that is how i keep my truck from shutting off.....but that is another subject. they will be pretty close to your exhaust pipe. if i remember correctly they are the only two plugs on that side. hope that helps.
Old 07-16-2004, 09:59 AM
you could by-pass the switch with some wire and a push button switch and two light sockets so you can get the inspection sticker ( i was born and raised in NY ) and that is what i did with my monte carlo until i got the tranny work done and it is legal to do this
Old 11-18-2007, 07:20 AM
mikeypan mikeypan is offline
morning all, ihave a 97 s-10 manual shift. i have chaecked the lights, and replaced the switch in the tranny. for the guy above, it's the one in the front on the passenger side. still no lights when in reverse. anything i should be looking at next. it's starting to get cold here. i don't want to spend more time than i have too undernieth it if i don't have to. does anyone have a wiring diagram i could get a scan from?
Old 11-19-2007, 03:01 AM
16th hippy 16th hippy is offline
well, if you are sure wich one the reverse light switch is, unplug it, and jumper the connector with a piece of wire and see if the lights come on. if so, then it's a problem with the switch or something inside tranny. if they don't light up, then is a problem with wiring and so on.
Old 11-19-2007, 06:14 AM
16th hippy, thank you, i tried this on my own in the afternoon. your solution works. i found out that there was just enough curorsion on the plug to stop the lights from coming on. i cleaned them and all is good. i hope this help some of the others out there.
Old 11-20-2007, 02:54 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
mikeypan, glad you were able to fix your problem, but this thread is over 3 years old. please refrain from posting in old threads .
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
