Old 07-10-2004, 10:28 AM
grease monkey girl's Avatar
grease monkey girl grease monkey girl is offline
what causes this?
when I shift the car into drive, it jerks forward. Only when I put it in drive, not in reverse. Someone told me it's motor mounts. What do you guys think?
Old 07-10-2004, 10:56 AM
Deadcarny Deadcarny is offline
Re: what causes this?
have somebody watch the motor when you do this. If the motor jumps to one side, it is the mounts. replace them with Energy Suspension Poly mounts and never worry again about them.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 07-10-2004, 12:22 PM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
ok my car does that too even in reverse i think its because of the power that the car puts down never worried me before
Old 07-10-2004, 12:32 PM
it doesn't worry me, but it meant something to my uncle when he rode in the car. he was like "what the hell was that?"
Old 07-10-2004, 01:36 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
lol, does he drive a yugo??????? just smile and say, thats my friend torque
but no that has to do with line pressure in the tranny, does the car actually move, like the brakes dont hold it???? if so you have a problem, but if the car just kinda jerks but dosnt move, id say youre fine.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-10-2004, 01:47 PM
yeah, it just jerks. so I guess I shouldn't worry (and I don't really)
He drives an olsdmobile.
Old 07-10-2004, 01:58 PM
89IROC&RS's Avatar
well something to try, and i just learned this myself, on the TPI cars, trace the throttle cables back from the throttle body towards the firewall, a few inches back from the butterfly lever there will be a black box that one of the cables goes through. push the square side into the housing, and then push the cable back inside of it towards the firewall. then let out the square button. now get in the car and push the throttle all the way down, and you will here the buzz of the cable adjusting its self. this is the kickdown cable for the trans, and was causing me major headaches cuz mine wasnt adjusted right. i fixed it, and MAN what a difference
Old 07-10-2004, 02:11 PM
I'll give that the old college try.
Old 07-10-2004, 03:56 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
what's wrong with Oldsmobile?
Old 07-10-2004, 04:28 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
yeah. ist normal like 89 was saying, but if its like that is ok too, its not the kickdown though its the throttle valve cable, sorry 89 but there is quite abit of difference. like he was saying, its the line pressure, when that cable is tighter it opens the throttle valve in the tranny more sooner and it creates more line pressure, witch creates fermer shifts. if you loosen it, well or corectly adjust it like 89 was saying then it will be right like it was saposed to be from the factory but it will change the shift charecteristics(spelling) some. the tighter the cable the fermer the shift, the looser the less responsive and crips the shift, not atlot but some, but also, too loose, and there goes your tranny.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 07-11-2004, 03:07 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Try readjusting your tv cable. After you adjust it back to factory specks, move it back towards the firewall one click. I PROMISE you will like the results
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-12-2004, 05:38 PM
hellraiser319's Avatar
hellraiser319 hellraiser319 is offline
Registered User
thish is a long shot, but how old are the rear brakes? if they goin bad then that could contribute to that thrust when u go in drive. Its a great feeling havinng all that power in front of ya tho. if you want, try to put it into drive over gravel, holding the brake like you would normally. if the wheel(s) spin or you slide forward, when that happens, id check out the back brakes to see if they are worn. o and by the way, i learned the hard way you dont wanna let those go too bad. if that car wasnt attacked by the cancer (aka rust) i woulda needed new wheel cylinders in back and lengthy bleeding procedure.
hope this helps a lil
hellraiser
