base and sl
so the only difference between a base and a sl is interior the engines are the same right.
Re: base and sl
i think after a certain year like 97 the base was sohc but what you said is correct
91'-95' Base and SL both have the same engine a 220hp dohc with about 205ft lbs. the only difference is the standard options. from 96'-99' Base models droped to a sohc with 180hp , and the reason being is because the dodge stealth stoped production in 96 which had the 180hp sohc so mitsubishi though they could take over the sohc market. which didnt realy work. but the sl stayed the same.
96 was dohc, 97 started sohc
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: i got the dl
Re: base and sl
your say you have a base with the dohc engine im guessing?
Tyler Laabs ![]() 2nd Place Drag racing Fwd 3s National Gathering 03[ |
Re: base and sl
All SLs were 222hp DOHC
91-96 base were the same as SLs engine wise 97-99 base were 161 or 164hp (can't remember which) SOHC engines.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
What were the standard options on an sl and base?
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Re: base and sl
Here are the 95 Specs for the Base and the SL
Specifications for the 1995 Mitsubishi 3000GT Base Number Madeš: 9102 Engine Type: 3.0 Liter V-6 Horsepower: 222 @ 6000 RPM Torque: 205 @ 4500 RPM Weight/HP Ratio: 14.6 Horsepower/Liter: 74 Compression: 10.0 : 1 Transmission: 5-Speed Drivetrain: Front-engine/FWD Valve Train: DOHC 24-valve Curb Weight: 3252 lbs. Tires: 225/55/VR16 All-wheel steering: N/A Active Aerodynamics: N/A MPG (City/Hwy): 19/25 Original MSRP: $28,991 Standard Equipment: 5-Speed Transmission, 6 cyl 3.0 L Engine, Air Conditioning, Aluminum/Alloy Wheels, AM/FM Stereo Tape, Center Console, Cruise Control, Dual Air Bag Restraints, Fog Lights, Infinity Sound System, Leather Steering Wheel, Power Antenna, Power Brakes, Power Door Locks, Power Mirrors, Power Steering, Power Windows, Rear Spoiler, Rear Window Defroster, Rear Window Wiper, Tachometer, Tilt Steering Wheel, Velour/Cloth Seats Optional Equipment: Automatic 4-Speed Transmission, Compact Disc Changer, Special Factory Paint Specifications for the 1995 Mitsubishi 3000GT SL Number Madeš: 4167 Engine Type: 3.0 Liter V-6 Horsepower: 222 @ 6000 RPM Torque: 205 @ 4500 RPM Weight/HP Ratio: 15.1 Horsepower/Liter: 74 Compression: 10.0 : 1 Transmission: 5-Speed Drivetrain: Front-engine/FWD Valve Train: DOHC 24-valve Curb Weight: 3351 lbs. Tires: 225/55/VR16 All-wheel steering: N/A Active Aerodynamics: N/A MPG (City/Hwy): 19/25 Original MSRP: $34,399 Standard Equipment: 5-Speed Transmission, 6 cyl 3.0 L Engine, Air Conditioning, Alarm System, Aluminum/Alloy Wheels, Anti-Lock Brakes, Center Console, Cruise Control, Dual Air Bag Restraints, Fog Lights, Heated Power Mirrors, Infinity Sound System, Keyless Entry System, Leather Seats, leather Steering Wheel, Power Antenna, Power Brakes, Power Door Locks, Power Drivers Seat, Power Steering, Power Windows, Rear Spoiler, Rear Window Defroster, Rear Window Wiper, Tachometer, Tilt Steering Wheel, Traction Control System Optional Equipment: AM/FM Stereo/CD/Tape, Automatic 4-Speed Transmission, Chrome Wheels, Compact Disc Changer, Power Sunroof, Special Factory Paint, Sunroof
Re: base and sl
Here is 97 when they dropped the base down since they stopped making the stealth.
Specifications for the 1997 Mitsubishi 3000GT Base Number Madeš: 3810 Engine Type: 3.0 Liter V-6 Horsepower: 161 @ 5500 RPM Torque: 185 @ 4000 RPM Weight/HP Ratio: 19.4 Horsepower/Liter: 53.7 Compression: 8.9 : 1 Transmission: 5-Speed Drivetrain: Front-engine/FWD Valve Train: SOHC 12-valve Curb Weight: 3131 lbs. Tires: 225/55/VR16 All-wheel steering: N/A Active Aerodynamics: N/A MPG (City/Hwy): 19/24 Original MSRP: $27,050 Standard Equipment: 5-Speed Transmission, 6 cyl 3.0 L Engine, Air Conditioning, Air Dam, Aluminum/Alloy Wheels, AM/FM Stereo Tape, Center Console, Cruise Control, Dual Air Bag Restraints, Intermittent Wipers, Leather Steering Wheel, Power Antenna, Power Brakes, Power Door Locks, Power Mirrors, Power Steering, Power Windows, Rear Spoiler, Rear Window Defroster, Rear Window Wiper, Remote Trunk Release, Tachometer, Tilt Steering Wheel, Velour/Cloth Seats Optional Equipment: AM/FM Compact Disc Player, AM/FM Stereo/CD/Tape, Automatic 4-Speed Transmission, Compact Disc Changer, Fog Lights, Infinity Sound System, Keyless Entry System, Leather Seats
