Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-10-2004, 05:00 AM
Scape Scape is offline
Send a message via AIM to Scape Send a message via Yahoo to Scape
question about burning out.
im not sure if this fits here but i thought it would (tires...). i have always wanted to know how to do a burnout. i would like to know how to do a burnout in FWD as well as RWD both in A/T and M/T. i would greatly appreciate to know. thank you.
Old 07-10-2004, 08:23 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
The basic idea is to get your tires to break loose from the pavement when pulling out from a stoping start. If you can get you engine RPM up high enough the tires will break loose and spin when you let out the clutch or put it into gear. That's pretty much it. Of course this would be on a track or drag strip and not on a public street
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 07-10-2004, 09:50 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: question about burning out.
just whatever you do, don't do a neutral drop on an automatic
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-10-2004, 07:52 PM
Blazing Rice Blazing Rice is offline
If you have to ask, you don't need to be doing them...
Old 07-10-2004, 11:18 PM
flsurf420 flsurf420 is offline
Send a message via AIM to flsurf420
is it really that bad to do a neutral drop? how bad will it **** up the tranny?
Too many hobbies, not enough time or money!
Old 07-11-2004, 01:53 PM
catback23 catback23 is offline
neutral drops shorten the life of the tranny considerably that is if they don't break it first.
Old 07-11-2004, 06:49 PM
drdisque's Avatar
a neutral drop is probably the stupidest thing you can do with a car.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 07-12-2004, 04:57 PM
Re: Re: question about burning out.
Oh, I don't know, I've done some pretty stupid suff in my younger days.
Grant
fax# 574-236-7707
Old 07-22-2004, 07:53 AM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
ok since no one really described to you how to do...i'll take my time and try to deterorate our youths mind. in an automatic tranny... (RWD) all you have to do is push the brake and hit the gas at the same time...will work if you have the power. (FWD) if you have sticky enough tires and an a good e-brake pull the ebrake and romp the hell out of the gas...usually will spin...again if it has power. Manual trannys are alittle more difficult and kinda takes practice. (FWD) same as AT put the e-brake...and just do a typical launch...push in clutch..1st gear...romp the gas, release clutch...(RWD) same motion as FWD but with out e brake, instead of hitting the e-brake you must you your regular brake...so when you drop the clutch immediately hit the break to stop you from moving and you'll sit and spin...those methods always worked for me anyways
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
