Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-10-2004, 03:46 AM
RicR_wana_B RicR_wana_B is offline
engine swap?
ive got a 94 ranger single cab, manual with a little crappy 4 cyl. engine, i was wondering if anyone knows if you can swap in a straight 6. from what ive been told the mounts are the same but i dont know if it will fit, so if anyone has any info or links that give info i'd really appreciate it
Old 07-10-2004, 05:22 AM
dmcoldhell's Avatar
dmcoldhell dmcoldhell is offline
Re: engine swap?
depends on the year of the motor but it should fit but measure just 2 be sure
Old 07-10-2004, 06:13 PM
TheRangerOfDanger TheRangerOfDanger is offline
I never have seen a slant 6 put in though...you should consider a v6 from another 94 so that you can get the factory motor mounts and have a much easier install....I think a slant 6 is too long
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD40.
Old 07-13-2004, 09:53 AM
gtmud gtmud is offline
Re: engine swap?
Keep in mind, changing the engines will require changing almost EVERYTHING under the hood. From the electrical harnesses, to your transmission. Good luck.
Old 07-13-2004, 11:12 PM
Re: Re: engine swap?
i know, thats why im kinda debating whether or not ill be able to do this but thanks for you help
Old 07-14-2004, 09:19 AM
dimarra dimarra is offline
Putting in a 5.0 V-8 requires modifying the heater for clearance and either moving the radiator forward or changing to an electric pusher fan.
Since the 6 will be approximately 6-8" longer than the V-8, you should plan on firewall modifications, too.
This COULD be a cool swap, but if you're looking for something bolt-together, you might want to try some other avenues.
If you do decide to persue this, might I recommend relocating the radiator somewhere else (the bed, maybe) and let the engine show through the grill.
I'm available to bounce ideas off of.
Keith
