Old 07-10-2004, 04:15 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
PLEASE! Wish me luck!
Well its that time......AGAIN! IF everything goes as planned tomorrow, I'll be starting my stang up again to see if it'll run, maybe even drive, this time. :
Question though. My cylinders are as dry as an 80 year old porn star so should I oil the cylinders by pulling the plugs? Or will 10 to 20 minutes of priming the pump w/ a drill be enough?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-10-2004, 10:26 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: PLEASE! Wish me luck!
Priming the pump should be fine. Nolonger than you will be turing the motor over w/out oil in the cylinders it shouldnt hurt a thing. It wont take long to get oil up to your wrist pins. If anything it will give your rings something to grab to so they can seat better.
