Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-09-2004, 08:33 PM
racer6 racer6 is offline
what does vr4 mean
what does vr4 mean? does it have a meaning i know it is 300 0r 320 hp and all wheel drive and the ultimate 3000gt but what does it stand for?
chris's bad azz 3000gt sl (''sucks gas & hauls ass'')
(chick magnet)
Old 07-09-2004, 09:21 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Viscous, Realtime-4
Resistance Is Futile (If < 1ohm)
Old 07-10-2004, 02:57 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
are you serious?
Old 07-10-2004, 07:09 AM
Re: what does vr4 mean
yes i am very serious
(chick magnet)
Old 07-10-2004, 08:46 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Seems funny that a Japanese car would be named in english, but I guess their biggest markets are Australia, UK, and USA.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 07-10-2004, 09:47 PM
joemathews's Avatar
joemathews joemathews is offline
If Yogs is serious about that, it is probably the worst name for a vehicle trim ever! *But I don't think he is serious
1996 Eagle Talon
Old 07-10-2004, 09:59 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The VR4 badge was first used in Japan on the 89 Gallant when a 4WD turbo model was released to compete in Group N and Group A rallying. The driveline from this car was then used in the Lancer to create the famous Evolution range which replaced the Gallant as Mitsi's primary rally car.
The Gallant got bigger and fatter, but still retained a VR4 model. However the 4cyl 4g63 was replaced by a 3l twin turbo V6.
They also got all sorts of electronic aids, and they were a variety of varients, including 2.5L V6 models, Legnum wagon versions, and even a VR4 GT model that had raised suspension and bug ugly bull bar style bumbers, and two tone paint.
Quite how the US spec GTO/3000GT ended up with a VR4 name on the Turbo AWD model I have no idea, as Iv never seen it on a Jap or NZ spec GTO/3000GT.
However, I have seen it in small letters on the boot lid of non-turbo 4WD V6 gallants with GLXi badges, my guess is it stands for exactly what Yogs said it does.
It certianly makes sense, and fits well with the Japanese style of badging.
Old 07-11-2004, 12:19 AM
YogsVR4's Avatar
Hate to say it, but I'm serious.
Old 07-11-2004, 12:24 AM
Hotshot8792 Hotshot8792 is offline
yes, it really does stand for viscous realtime 4
as for JDM cars, there are no VR-4s in Japan, this is what they have:
SR: AWD N/A
Twin Turbo: Equivelant to a U.S. VR-4
MR: same as the Twin Turbo, except it weighs less, and had the option of 13g turbos, which would explain why they run 12.7 in the 1/4 at stock boost levels. I think i once heard that they are mid engined if anyone can confirm if they are or not.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-11-2004, 03:46 AM
Yaggus's Avatar
Yaggus Yaggus is offline
Send a message via ICQ to Yaggus Send a message via MSN to Yaggus
SR: AWD N/A
im pretty sure that the MRs's arent mid engined.
stats
SR
Make Mitsubishi
Family GTO
Model Variant GTO SR
Year August 1998 to 2000
New Price 299.8 ten thousand Yen
Body Type Coupe
Seating Capacity 4
Engine Code 6g72
Engine Type V6 DOHC 24 valve
Engine Size 3.0 litres (2972 cc)
Bore × stroke 91.1mm × 76mm
Compression ratio 10:1
Fuel system
Max power 165kW @ 6000rpm
Max torque 274Nm @ 4500rpm
Forced Induction No
Fuel Tank Capacity 75 litres
Fuel type Unleaded premium gasoline
Fuel Consumption 10.9 l/100km
Transmission 5 speed manual
Drive Layout FULL4WD
Steering Type Power assisted rack & pinion
Front Suspension MacPherson struts
Rear suspension Double wishbone
Front brakes Ventilated disk
Rear brakes Ventilated disk
Front tyres 225/50R17 94v
Rear tyres 225/50R17 94v
Turning circle 11.4 m
Exterior Length 4600mm
Exterior Width 1840mm
Exterior Height 1285mm
Interior Length 1570mm
Interior Width 1510mm
Interior Height 1070mm
Wheelbase 2470mm
Front Track 1560mm
Rear Track 1580mm
Ground Clearance 145mm
Weight 1600kg
Standard features Front fog lamps, Projector headlights, Rear spoiler, Rear window wiper, Driver airbag, Front passenger airbag, Anti-lock braking system, Rear seat lap sash belt, Side impact protection bars, Power windows, Central door locking, Steering wheel height adjust, Leather steering wheel, Alloy wheels
Optional features Limited slip differential, Navigation system, Leather seats
Twin Turbo
Make Mitsubishi
Family GTO
Model Variant GTO twin turbo
New Price 432.3 ten thousand Yen
Body Type Coupe
Seating Capacity 4
Engine Code 6g72 (twin turbo * twin intercooler)
Engine Type V6 DOHC 24 valve IC twin turbo
Compression ratio 8:1
Fuel system
Max power 206kW @ 6000rpm
Max torque 426Nm @ 2500rpm
Forced Induction IC equipped twin turbo
Fuel Consumption 12.5 l/100km
Transmission 6 speed manual
Front Suspension MacPherson struts (ECS)
Rear suspension Double wishbone (ECS)
Front tyres 245/40ZR18
Rear tyres 245/40ZR18
Turning circle 11.8 m
Wheelbase 2470mm
Front Track 1560mm
Rear Track 1580mm
Weight 1680kg
Standard features Limited slip differential, Front fog lamps, Projector headlights, Rear spoiler, Rear window wiper, Driver airbag, Front passenger airbag, Anti-lock braking system, Rear seat lap sash belt, Side impact protection bars, Power windows, Central door locking, Steering wheel height adjust, Leather steering wheel, Power front seat adjustment, Alloy wheels
Optional features Navigation system, Leather seats
MR
Make Mitsubishi
Family GTO
Model Variant GTO twin turbo MR
New Price 397.9 ten thousand Yen
Body Type Coupe
Seating Capacity 4
Fuel system
Wheelbase 2470mm
Front Track 1560mm
Rear Track 1580mm
Weight 1670kg
Dont ask about performance stats cuz i couldnt find them....
Previously... --------| Now....
St185 GT4 Celica ---| SW20 MR2 Turbo Hardtop
TT Z32 300zx ------| Rebuilt engine with race head
TT Mitsu GTO ------| Apexi AVCR, Dual 2 1/2" Exhaust, T3/T4 turbo, BOV
--------------------| Lowered King springs, Bilstein Struts & Shocks, Whiteline swaybars, Cusco Strutbraces
--------------------| 17" Advanti Rims, Kenwood Stereo, 94+ Tailights
K3:i have had this itch... the itch to bang a somewhat chunky girl... like i want it to jiggle a little
Old 07-13-2004, 08:40 PM
Twyzz Twyzz is offline
Send a message via AIM to Twyzz
the mr stands for Mitsubishi racing, just like the Evo MR
Old 07-14-2004, 02:47 PM
thre3kgt811 thre3kgt811 is offline
Originally Posted by YogsVR4
Viscous, Realtime-4
what the heck does that mean???
Old 07-14-2004, 03:06 PM
Igovert500's Avatar
blue + red light magnet
viscous coupling is a type of differential that links your front and rear so if the front or rear start breaking loose and lose traction, the torque is transfered to the other set to allow the wheels without traction to lock up again. Realtime-4(AWD, not part-time 4WD).
To learn more about differentials:
http://auto.howstuffworks.com/differential.htm
And just go through all the pages, it is really easy to understand, and helped me the first time.
Or to simply skip to viscous coupling:
http://auto.howstuffworks.com/differential9.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-15-2004, 05:38 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
The HSX brocure says VR4 stands for viscous realtime all wheel drive with 4 wheel steering.
That explains why the galant is a VR4 and the eclipse is not, dispite being a vicous coupled AWD system.
Old 07-15-2004, 11:55 AM
BB1970's Avatar
BB1970 BB1970 is offline
slightly off post but the mitsu evolutions had a model called the FQ350 or FQ300 and i laughed my head off when i was told why it was called that.
this is gospel and it meant f***ing quick 350hp
i think its the japanese sense of humour.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Closed Thread
