Old 07-09-2004, 07:04 PM
cody911911's Avatar
cody911911 cody911911 is offline
dual voice coil sub question
Ok I hooked up one of my friends subs for him about a month ago and I am wondering if I did it correctly. It was a rockford 12 " not sure of rms or stuff but it was 4 ohms resistance. I conected the positves and negatives to each other on the sub itself then ran the "spare line" to the amp where I had it bridged that is something for watts at 4 ohms. what kind of load would this be running on the amp? It is a 2 channel amp would it be better to run each voice coil on its own channel?
1st rule of drinking and driving.......you gotta have a beer.....
Old 07-09-2004, 07:10 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: dual voice coil sub question
I'm guessing it was dual 4ohm (each coil was 4ohm)?
If so, you have it wired to 2ohm, and the amp is only stable at 4ohm bridged. This will shorten the life of the amp, and chances are it will cause it to go into protection at high volume.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 07-09-2004, 07:16 PM
cody911911's Avatar
ya it is a dual I forgot to say that somehow would it be better to run each coil on its own channel?
Old 07-09-2004, 07:19 PM
sr20de4evr's Avatar
well, if you did that the amp would be happy, but you would get 1/4 as much power going to the sub. The choice is up to you *shrug*
'01 Black Sentra SE
'05 Silver WRX STi
Old 07-09-2004, 07:24 PM
cody911911's Avatar
it is a Kenwood 1000 watt supposidly, think it could handle it I wanna say it was 200 watts rms at 2 ohm out of each channel not sure though and I think the sub was an HE
Old 07-09-2004, 07:36 PM
sr20de4evr's Avatar
so right now you would be pulling about 6-800 watts out of the amp at full output before it shit itself
If you wired each coil to each channel then you would get 200 reliable watts.
You can leave it as it is if you want, but don't be surprised if the sub dies (from all the power) and takes the amp with it, or if the amp just dies from being run at 2ohm mono.
'01 Black Sentra SE
'05 Silver WRX STi
Old 07-11-2004, 09:40 AM
cody911911's Avatar
k ill probably switch it to each coil with its own channel but i haven't talked to my freind in quite some time and he wouldn't know what the heck i was talking about if I told him how to change it.
