Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 07-09-2004, 07:29 PM
JohnnyWadd JohnnyWadd is offline
Are ECU's interchangeable?
I think the ECU is shot in my car, and I was wondering if anybody knows anything about replacing them. What I want to know is whether or not I have to replace the ECU with another one of the exact same type. Do the numbers have to be an identical match, or can certain numbers be interchanged for each other?
My car is a 1991 Talon TSi 2.0 Turbo FWD. The ECU I pulled from my car is numbered MD166260. There's another number under it that says E2T36574M. There's also another sticker on the side that says 6260 on it. Do I have to find another one with the same numbers, or is there another one that will work? If I have to be exact, anybody out there know anyone with a spare MD166260 that they're wanting to part with?
Thanks
Jon
Old 07-09-2004, 08:15 PM
Re: Are ECU's interchangeable?
Forgot to say that it's a 5-speed.
Old 07-10-2004, 06:13 AM
Would an ECU out of a 1990 Laser 2.0 Turbo FWD 5-speed work in my 1991 Talon TSi 2.0 Turbo FWD 5-speed? The number for the ECU from the Laser are MD128625, with E2T34474A written under that. Would that work in place of my MD166260, with E2T36574M written under it? The throttle bodies on the two cars are different. That means that at a minimum, the ISC Motor is different. TPS is probably different as well. What do you think? Will it work?
Thanks
Jon
Old 08-18-2005, 03:36 PM
amakar amakar is offline
I have an MD166260 that apparently will not work in my car, I have a 1992 Mitsubishi 2.0 turbo automatic. If still interested please let me know. I do need an ECM that will work with my setup so if you or anyone has one I can certainly use it.
Thanks
Jon
Old 08-20-2005, 07:39 PM
fbbud fbbud is offline
Re: Re: Are ECU's interchangeable?
i need that ecu if you still have it im interested MD166260
Old 01-07-2009, 09:32 PM
jahdea jahdea is offline
I had the same problem MD176813, Mitsi Chariot....I can say they are not interchangeable, Even if the same year and model make, Check this link
http://www.atpelectronics.co.uk/Catalogue/option.htm#6
