Old 07-09-2004, 06:17 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Question Help Info Advice on mini me
Ok well i recently dropped in my a6 and i have a z6 head laying around. I went out bought head gasket intake manifold gasket and exhaust gasket and valve cover gasket set. I also got commandflo fuel regulator and MSD rpm activated switch for vtec. I kinda ran outta cash now and unfortunately i gotta use old head bolts oh yeah and got the timing belt. Em i missing anything? I just want this swap to go smoothly. and when i run into a bind i run up to gather info from u hondaholics so ur input is appreciated thanks
Old 07-09-2004, 10:59 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Help Info Advice on mini me
Um spark pligs would be nice,lol
um a new distributor seal would be good also, but besides that you should be good to go!!!!!!!
Old 07-10-2004, 02:03 AM
Hybrid1990crx's Avatar
Don't worry about using old head studs. I reused my stock ones on my a6 when I replaced my headgasket. Just make sure you mark where each one came out and put it back in the same one.
Old 07-10-2004, 03:33 AM
audioquattro audioquattro is offline
you should be fine with what you have until you get around to replacing the dizzy cap, rotor, plugs, wires, changing your oil and coolent....blah blah blah
FOR SALE
Si 5 sped trans w/ low miles 100.00
SOLD
Old 07-10-2004, 07:34 AM
Well thats cool, my valve cover has no hardware at all, guess i prolly have to go to Honda for that stuff huh? i dont even have the 10mm bolts to bolt the solenoid down. my old ones wouldnt work would they?
