Old 07-09-2004, 05:09 PM
GrandAmOwner02 GrandAmOwner02 is offline
Unhappy Blinker Sound won't turn off!
Hey everyone, I drive a 2002 Grand Am. Recently, the blinker sound (you know that clicking noise) won't turn off! I'm sure its the blinker. Yet I can't figure out how to make it stop. As soon as I start the car the noise starts with it, just a high paced clicking noise.
Now I've checked and the blinker and the hazards both work normally when used. But when you turn them off, the noise remains. The noise eventually stops but will just randomly start again, sometimes just a few clicks, other times for spans of 10-20 minutes.
Some help would be greatly appreciated as its driving me insane!
Old 07-10-2004, 06:50 PM
SAM99 SAM99 is offline
Unhappy I have the same annoying sound!!!
I also have the same noise that randomly turns on when I'm driving! I have a 1999 Grand Am and would love if anyone could help us!!!
Old 07-21-2004, 12:54 PM
Vc1612 Vc1612 is offline
I have a 2000 Grand Am that has the same problem. Does anybody know how to stop it? It drives me nuts.
Old 07-21-2004, 07:10 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Blinker Sound won't turn off!
Have any of you got the recall done? It to replace the hazard flasher, should cure your problem.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 07-21-2004, 07:42 PM
Pvt_Murphy Pvt_Murphy is offline
Exclamation
It sounds like the only recall on this car is what you need; its the blinker/hazard lights relay that makes that noise; it's borked in 2000-2002 year cars; free quick fix at dealership;
Mods; should make the details of the recall a sticky; this comes up often enough
Heres the info on the recall:
http://www-odi.nhtsa.dot.gov/cars/pr...fsDocId=03V327
1977 Pontiac Trans Am Olds 403
Rolling like the Bandit!
Old 07-22-2004, 11:13 AM
Except that recall is only on the 2000-2001's... despite having the SAME problem in their 2002 model, something tells me the dealer won't be fixing my car for free (at least until the new recall comes out, hopefully soon, as its driving me insane!)
Old 07-22-2004, 01:40 PM
GrandAmOwner1999 GrandAmOwner1999 is offline
Angry
I don't think there was a recall for 99s either, cause the dealer wanted $300+ to fix it. I'm now trying to find the wire to disconnect the noise.
Old 07-24-2004, 10:40 PM
What is making that nose is the relay; a relay basically switches a (+) node between 2 outputs; in this case one goes to nothing (blinker off) and one goes through the blinker light to ground (-). The way it switches is by powering an electrical magnet which pulls a metal blade toward it and it hits the 2nd contact. So the sound you are hearing is the sound that every relay makes; it's that leaf hitting the contact compeleting the circut to turn the blinker light on and off. So you cannot disconnect the power to that realy because the your blnkers will not work. If you still don't get it visit howstuffworks or google how relays work or something.
Old 07-25-2004, 01:12 AM
Froggy69 Froggy69 is offline
my 96' suburban does the same thing.
pvt murphy-when the relay is making the noise in my suburban the lights are not coming on which i'm sure is the same thing that it is doing in the GA's
Old 07-25-2004, 07:36 PM
could be because the circuit wasnt completing for a long enough time, depends on how fast it's going. When i had that problem it was a buzzing sound.
Old 07-26-2004, 04:35 PM
Talcan Talcan is offline
Send a message via MSN to Talcan
its not the flasher, its the controle stick on the colum, i had that same prob take it to gm and get them to fix it... or get th parts from the, because that the only place youll find them
Old 08-21-2004, 03:47 PM
GUYASC GUYASC is offline
Send a message via Yahoo to GUYASC
Blinker noise
I have a 2001 Grand am se. Mine blinks to. I took it to the dealership for the recall (flash switch) and they replaced it. However, it still does it. I think it is with the blinker arm. Also I had a coolent leak...took it to a shop and was told it was a intake manifold leak (300.00) to fix. Decided to try and figure it out myself and found that the bolts had backed out. Tightened them and it stopped for 10,000 mi. Tightened again with locktight and never had a leak since.
Old 08-22-2004, 09:48 PM
can anyone quote prices on getting this clicking thing fixed?
price of the handle or the flasher? Just would like to know some ballparks before I take it to the shop.
