Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-09-2004, 03:48 PM
highteknology's Avatar
highteknology highteknology is offline
Send a message via AIM to highteknology Send a message via MSN to highteknology
Question difference between engines
what is the difference between a b16 and a b18 engine and all the other ones? i'm just curious, partially because i'm buyin a new car.
Old 07-09-2004, 03:51 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: difference between engines
well there is the 1.6 from the b16 and the 1.8 from the b18. Also the b16 comes in the A and B trims and the b18 comes in A/B/C trims
the b16s are all vtec the b18c is vtec the b18a is older motor b18B is also called LS
damn it im lazy find the rest your self
Old 07-09-2004, 06:48 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
b18c1 more acceptable to turbo b/c of lower compression
b18c5 more acceptable to n/a, because of higher compression
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 07-09-2004, 07:21 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Not to confuse, but there's also B17 (2nd gen Integra motor, 1st gen came with a DOHC D-series motor) and also B20 which is found in the CR-V Sport Ute. The B20 makes a bit more torque than any other B-series motor, mainly because it drives an AWD drivetrain and it's also in a truck per-se, so it needs more torqueness to handle what it might get into. The B17 is pretty weak in comparison, and if i remember right only put out 140hp and something like 112lbs./ft of torque (or somewhere in that neighborhood). There was also a B21 I think, but I can't remember where I've seen that from, or it could be some swap hybrid motor, ugh D-series is what I know about, so my B knowledge isn't quite as up to par.
So why do you ask the differances?
EDIT:
haha, I figured I was off on a few things there... Ok, here you go, B-motors and what car/year and hp output of each
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
I KNEW the B21 existed!
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 07-11-2004, 08:35 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Actually silvery2k the B17 is a great motor, it is basically a stroked b16, producing 160 hp and 117 ft/lbs.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 07-12-2004, 04:06 AM
Cali Guy
Your right, I was thinking it was less HP than the B16 for some reason. I wonder why you never hear of hybrid builds using the B17 block...
hessemer69 on AIM
Old 07-13-2004, 08:54 AM
knorwj's Avatar
easy, they are very difficult to find.
I've already had people offer me 400 just for the crankshaft out of my B17.
Old:
New:
Newer:
