Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 07-09-2004, 01:10 PM
ljrpclady ljrpclady is offline
Question P0421 code -- HELP!!!
I've had the P0421 (warm-up catalyst system below threshold) code pulled from my car twice. The first time the shop said that if it came on again, take it to the dealer due to the 8 yr emission warranty. The light came back on, I took it to the dealer, dealer pulled the same code & said that before Mazda would cover the replacement of the cat under the emissions warranty, BUT FIRST I had to have some work done to "clean" then engine since it was running "dirty", THEN if the light came back on, they would replace the cat. The work they want to do is (1) 4 cyl tune up - $50 (ok, maybe), (2) replace the plug wires - $136 (why? I have no problems with power loss or troubles starting it when it rains), (3) injector service - $90 (why? I only have 38,000 miles), (4) throttle place service - $80 (unlikely, but maybe). Obviously, I think they are milking me for $$, but I'm not exactly sure what I should do about it, or what the P0421 code is telling me is really wrong. Any suggestions would be greatly appreciated!!
Old 07-09-2004, 01:11 PM
forgot to mention...
Forgot to mention I have a '99 ES. Thx!!
Old 08-17-2004, 02:49 PM
flundber flundber is offline
Re: P0421 code -- HELP!!!
Just had same problem Dealer replaced CATS with no questions Cause CAT Converter coming apart??
No cost car had near 71kand is a 98. The inpression I got was this may be common???
Old 06-26-2006, 08:35 PM
Has anyone else had this problem?
Old 12-20-2006, 01:17 PM
Doug Tatham Doug Tatham is offline
This is a quote from: http://www.obd-codes.com/trouble_cod...old-bank-1.php
A code P0421 may mean that one or more of the following has happened:
* The catalytic converter is no longer functioning properly
* An oxygen sensor is not reading (functioning) properly
* A sparkplug is fouled up
It doesn't sound like anything that they did is likely to help or was necessary (or correct) given the error code. I'd find a new shop.
Old 12-20-2006, 08:54 PM
mazdatekchubyninja mazdatekchubyninja is offline
Your car needs a CAT put on. The dealer was making sure that once they put the new one on it won't be killed by misfires / lean or rich condition.
Old 10-04-2010, 11:49 AM
chapper chapper is offline
Bump... I have the same issue in my 2001 ES, I let the spark plugs go too long, got some misfires and this code shows up. Took it to dealer and they said the pre-cat needs replacement, which sucks b/c it is almost $1000
Is it advisable to get one off a junk car, or do those disappear due to precious metal content?
Are there any aftermarket options that are cheaper? Thnaks in advance
Old 10-04-2010, 12:48 PM
danielsatur danielsatur is offline
You can buy OEM @ http://www.catalyticconverterwarehouse.com , and have a local muffler shop do the install.
Old 01-10-2011, 12:38 PM
YOUNGMAZDA YOUNGMAZDA is offline
I have the same problem the error code kept coming on P0421 I finally got the cat converter and a new muffler. Less than 24 hours later the code came back so now what? My inspection sticker is due this month? Do I get the oxygen sensors fixed and if so which ones? Or should I get them both fixed ?
Old 01-10-2011, 01:23 PM
Doe's this car have Heated oxygen sensors (HO2), you might just have a blown fuse.
1) Visual inspect wiring to the H02 sesnors.
2) Roll the down stream H02 sensor from bank1 to bank2.
Downstream H02 sensor are the ones, after the catalytic converters.
Old 04-21-2011, 07:39 PM
OK, update.... I replaced the CAT, waiting to see it the code comes back. Got a Bosal CAT and some gaskets from PartsTrain for about $215. Of course they sent the wrong upper gasket... and as it turns out, only mazda dealers carry the upper gasket for like $28 (at least I couldn't find one). Also, the Mazda cat had studs to bolt to the front pipe... the Bosal cat had holes, so I had to buy exhuast bolts... another $8. Overall, it took me about 6 hours to pull it apart and then put it back together... and I am not terribly experienced, so someone else could prob do in half the time. I will post back if something goes wrong... like if the car catches fire etc...
Should have seen the old cat... it looked like a bomb went off... at least 2/3rds of the ceramic honeycomb was gone.
Old 04-28-2011, 12:24 AM
autoteck21 autoteck21 is offline
hello my name is kenny heres your help
now the codes such as po420 or p420 they would replace no ? asked now 421 is a little different < now they wont replace the cat because your engine is running rich you wont notice all the time if ever but running rich and in some cases lean will kill a cat and then they would have to replace again< to much money for a warranty job, anything elts just ask or e-mail me anyone, and yes i am an auto tech and own a protege dx
Old 09-27-2011, 10:55 AM
fm2384 fm2384 is offline
Autoteck21 I saw your last post. I've got a Mazda 2002 Protege5 and am also getting the PO421 error code. Here's what I've had done in the last 3 weeks:
On 9/2/11 had following error codes: P0300, P1569, P0171
-replaced: cold air pipe, solinoid, water pump, timing belt, spark plugs, coolant.
9/4/11 car suddenly developed an idling problem at a stop light and check engine light came on flashing. As I started driving it barely had any power (I have a stick) so I drove it to a big parking lot where I knew I'd have it towed. As I pulled in it stalled on it's own. Mechanic said my fuel pump was bad and a miss fire code was present so had fuel pump it replaced. Misfire code removed.
9/7/11 picked up car day before, ran like a champ! In the afternoon I got in it and the idling issue was back and car had same issue where I could barely get any power and car is bucking, check engine light flashing again. This time I drive it all the way into the mechanic since I know it's a misfire. It wants to stall anytime I come to a slow speed/stop.
9/12/11 pick up car, mechanic replaced 1 coil pack free of charge, cleared out misfire code.
9/14/11 check engine light comes back on. I stop at autoparts store and get a misfire code P0300 and P0421.
9/19 take it to a different mechanic, they can't find anything wrong with it and the only code they get is the P0421.
9/27/11 stop at autoparts store to see if I'm getting any other codes besides the P0421, nope that's the only one.
I get the impression it is the cat. converter based on what I've read on here but have been unable to find an aftermarket part/s. Do you have any suggestions or ideas, or anything else to try in reference to my situation.
Many thanks in advance to anyone who can help!!!
Old 10-03-2011, 12:19 PM
If you are still misfiring then you should still get P0300 or something to that effect. When I had this issue (2001 Protege ES2.0, not a 5), it ended up being the coil packs. You mentioned you had one replaced... go ahead and replace the other too. P0421 is probably the Cat, I had to replace mine too, but it shouldn't cause the engine to misfire. If your car is setup like mine (and I think it is), there are two Cat's... the bad one is called the Pre-Cat and it is attached to the exhaust manifold. You can get an aftermarket Cat for about $300... if you get mechanic to do it, you could be looking at $800-$900 bucks. From other research I did on this board and others, the problem occurs like this: engine starts to misfire for some reason.... unburnt fuel gets dumped into the Cat which ruins it and the honeycomb falls apart... computer notices and throws that P0421 code.
Old 10-04-2011, 11:14 AM
Thanks for the response Chapper. I have replaced the 2nd coil since my last post. No more misfires. I'm having a difficult time "assuming" it's the cat. The car has never had the rotten egg smell, there has been no further hesitation, choking/puking. Also my mileage has remained the same. Thru further research I found a similar incident where the mechanic was ready to do the "standard" replacement of the cat and o2 sensor but decided to do some further DX tests and discovered it was the Mass Air Flow Sensor. I'm thinking it would be worth the $90 to take the car and have it hooked up to a diagnostic machine to rule out other possibilities. I've even wondered if it's a computer issue.
Any other feedback is welcome since it will be another week before I can get it to the shop.
