Old 07-09-2004, 06:10 AM
frijoleo frijoleo is offline
ford F150
i have a 99 ford F150 with 6 cylinder eng well the check eng light was on i hook up the scaner it gave me a EGR- flow out of range code 1408 i replased it and the check eng light came back up with the same problem i also got a code 1464 a/c deman out of self test range what does that mean if some body could help i would a ppresiate it thank you
Old 07-09-2004, 01:40 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: ford F150
Not sure why this was in Buick, I'll let the Ford guys sort this one out.
Moved from Buick Regal->Ford F-Series
Old 07-18-2004, 02:09 PM
Paul Masley Paul Masley is offline
Re: ford F150
On the front of the throttle body is a retangular sensor unit with two hoses coming out of it and an electical conntector. You will have to remove the plastic throttle linkage to see it. This is a common failure, but most mechanics will replace the egr valve first. I have yet to see an egr valve go bad on the 4.9L, but this sensor will cause a lot of trouble. It will also cause the same problem on the 5.0L.
For the 1464, check you blower switch ans see if you have all ranges. If you do not, look under the passenger side of the hood. You will see a 4 wire plug going into the A/C box. Remove the two screws holding it and look at the control unit. If you see any burns, replace it. While there, clean the debris out of the case with a small tube vacuum cleaner. Debris, like leaves, will short the unit out.
Everybody is an idiot (including me) some of the time, but there are others that make a full time job out of it!!!!!
Old 07-19-2004, 12:34 AM
frijoleop frijoleop is offline
i replased the regulator sensor with the 2 vacum houses and i stil get a p1408 any o ther sugestion by the way its a 4.2L thanks
Old 07-19-2004, 07:59 PM
Re: ford F150
If you are still getting this code, it could be a possible number of problems from a cracked or blocked vacuum hose, blocked EGR tube, stuck EGR valve or the electronic vacuum regulator failure.
I would start with the egr valve and tune and make sure that it is free and clear. It is a job but you will need to loosen it at the block and make sure that you can blow easy through it. Also check the two vacuum lines to the DPFE sensor and the vacuum line coming out of the top of the EGR to the regulator. If these are clear, you may have carbon/sludge blocking the area where the EGR tube attaches to the block.
This will be trial and error. A cracked vacuum hose is hard to find, especially if your tubes are the hard plastic that Ford seems to like to use now. They are routed through the harnesses.
Old 07-20-2004, 01:31 AM
well i fallowed the vacum lines from the DPFE sensor and found out that the vacum resevoir ( inside the passenger fender wel) and it was broken replased it and im no longer getting a egr code.
thank you for ur help
Old 07-23-2004, 08:06 PM
Re: ford F150
You be quite welcome. Glad I could help.
