Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-09-2004, 04:26 AM
outrageous outrageous is offline
New Stereo no sound from Rear speakers
Ive tried installing my new stereo into my 99 prelude. The only problem is that I get no audio from my rear speakers. From what I have read up its because of the Acoustic Feedback System. What I can tell from reading about it is that if I directly connect the head unit directly to the rear speakers I will blow out my head unit. So can anyone tell me how to wire through the AFBS and make my rear speakers work? This would help a lot. Thanks.
Old 07-09-2004, 10:47 AM
crzyCollegeKid crzyCollegeKid is offline
Re: New Stereo no sound from Rear speakers
i thought the AFS system was just a little amp, it should work by just plugging in. if you haven't...try reading this...its possibly the best guide to 5th gen audio.
http://personal.jax.bellsouth.net/v/...ludeaudio.html
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 07-09-2004, 03:58 PM
Yea Ive read that in and out. But it doesnt tell me how to fix the rear speakers. In fact it seems a bit contradicitary because it says "you will overheat the head-unit if you attempt to connect these directly to a typical head-unit (if you are trying to by-pass the AFBS amp)" and then it has a section called "Can I use a new head-unit with the AFBS engaged?"
I have read about people having simmlar problems but no one posted a remedy for it.
Has anyone installed their own head unit and ran into this problem?
Old 07-09-2004, 05:00 PM
dbebesi's Avatar
dbebesi dbebesi is offline
put in some aftermarket speakers
Old 07-10-2004, 01:49 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
check out how you hooked up the speakers. On my deck there are two way's to setup the speakers, and on one way, the back speakers get connected to the subwoofer function. If you have a subwoofer control on your deck, make sure it's on, or make sure you have everything running to the right outputs.
Old 07-10-2004, 01:50 AM
what brand and model head unit is it by the way?
Old 07-10-2004, 05:52 AM
bumpn lude bumpn lude is offline
stop what u r doing!!! first check if the rears are hooked up to the afbs. if u havent touched them yet then they should be. now this means you wired your hu wrong. all you got to do is match the colors up. i think on the 5th gens they even have tabs that say "rear" or "front" on the wires. all u got to do is match them up with the hu. just asking, did u buy a wiring harness?
Old 07-10-2004, 04:52 PM
Its a Blaupunkt San Jose head unit.
Yea I checked the AFBS all the wires are connected. I'm preatty sure I wired my head unit right, I even brought two wirring harness because I thought one was one defective.
