Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-09-2004, 03:16 AM
91_T-Bird_HO_5.0's Avatar
91_T-Bird_HO_5.0 91_T-Bird_HO_5.0 is offline
Send a message via AIM to 91_T-Bird_HO_5.0 Send a message via MSN to 91_T-Bird_HO_5.0
Rim sizes in width
what would be the biggest rim size you guys would go for in width, i'm thinkin' about gettin' some new rims for my car, but i dunno what width to go with, i'm goin 17" , i'd like to go with a 17x10 but i dunno if it'll rub or not, if it will then i think i can go 17x8 safely. what do you guys think?
i wanna go with these rims
http://jr.stangnet.com/Cobra%20Images/DSC00421.jpg
http://jr.stangnet.com/Cobra%20Images/DSC00420.jpg
http://jr.stangnet.com/Cobra%20Images/DSC00422.jpg
Old 07-09-2004, 01:50 PM
94GreenBeast 94GreenBeast is offline
Send a message via MSN to 94GreenBeast Send a message via Yahoo to 94GreenBeast
Re: Rim sizes in width
Where did those rims come from? Web-site?
Old 07-09-2004, 02:49 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
i belive the widest you can go with, with only rubbing in extreme cornering is 275 wide tire. So what ever fitsa 275.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-12-2004, 12:32 PM
RavenProjecT RavenProjecT is offline
Send a message via AIM to RavenProjecT
There's a guy in my town sporting 20x9s un-bagged, no rub (except under heavy load) on his mn-12. 18x9s are as big as I would go personally, I would say the 10s would rub, and the backspacing will be greater, causing the tire to stick out slightly from the fender well. Rolling the lip of the fenderwell will be necessary and even then might stick out slightly >>>> 17x7,8,9, or 18x7,8,9 are my overall recommendations for proper "bolt-up" fitment with minimal hassles.
