Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 07-09-2004, 03:06 AM
adetemp1 adetemp1 is offline
Renault Clio noise from drivers side wheel - help!!
I have a grinding/buzzing noise and a slight vibration coming from my front drivers side wheel area. It only occurs when i turn right, Im assuming that this is not good and would appreciate any ideas in what it might be?? possibly wheel bearing? UV Joint perhaps? Im really not sure as you can tell!
please help
Old 07-09-2004, 04:56 AM
tiggerthedude tiggerthedude is offline
sounds like CV joint.
Old 07-09-2004, 01:59 PM
mechy1barry mechy1barry is offline
Re: Renault Clio noise from drivers side wheel - help!!
grinding or buzzing sounds more like wheel bearing or perhaps worn brake pads.if it only happens when you turn right,i would suspect the n/ s front bearing(or rear)
Old 10-05-2005, 12:53 PM
sparky1.45 sparky1.45 is offline
Send a message via MSN to sparky1.45
yeh i have the same problem dunno wot it is but the grinding noise def aint the brakes been told it might be summin to do with the steerin rack
