Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-08-2004, 11:40 PM
cayman66 cayman66 is offline
Send a message via AIM to cayman66 Send a message via Yahoo to cayman66
engine knock
i have a 91 islander with a 6cyl,,it recently started knocking while accelerating,,i dont hear the knock while at idle or when i stay at a constant speed.only hear it when under a load..should i do a compression test?acceleration hasnt dropped.and doesnt seem to burnin excessive oil...
Old 09-23-2004, 07:31 PM
YJ_steve YJ_steve is offline
Re: engine knock
check your header bolts. mine started knocking cause i lost a bold in the header. also, obviously check your oil level.
Old 09-27-2004, 05:54 AM
gtmud gtmud is offline
Re: engine knock
Keep a close eye on your oil pressure! If you don't have a guage install one. If it sounds like a bottom-end "hard knocking" you could have a bearing failure, or it could be "piston_slap".
