Old 07-08-2004, 09:55 PM
april15_ april15_ is offline
hesitation on acceleration, stuttering noise
My 94 Grand Am hesitates for a second when I accelerate from a stop. It doesn't happen all the time, but enough that I am afraid to pull out into traffic. I'll step harder on the gas when it happens and then it suddenly moves. Also, I'm hearing and feeling a stuttering while the car is idling. It happens in all gears and it also happens occasionally on the highway at high speeds. It sounds kind of like a palpitation. Took the car to the mechanic and he replaced the spark plugs, but the problems are still happening. Can anyone guess what might be the problem? Thanks to anyone who can help.
Old 07-09-2004, 08:53 AM
gebster76 gebster76 is offline
I would have the catalytic converter checked out. Sometimes it can get clogged or damaged and some people think it's a tranny problems and spend huge amounts of money and then come to find out it was the cat all along.
Old 07-10-2004, 12:00 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: hesitation on acceleration, stuttering noise
I would go ahead and clean the gunk off the IAC and test the IAC (Idle Air Control solenoid) and if not then replace the IAC.
Old 07-10-2004, 12:33 AM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
Clean your Mass Airflow Sensor.
had the same problem here.
Old 08-20-2004, 03:47 AM
charleshenryjr charleshenryjr is offline
Thumbs down engine blown
mine too, i just got it, so i figured i was just in third. now i know different by reading all these, engine posts. my engine just went out. fried. soon after repairing and heavy use of the a/c, pontiac dealer says $440 to get car running to perform a diagnostic, also quoted $5k for new delco engine, didn't research rebuild or used install.
Old 08-20-2004, 03:48 AM
Thumbs down ga slow off the line, though i was in 3rd
p.s. also 94 ga, se, quad, sohc
Old 08-20-2004, 12:56 PM
Tom94gaGT Tom94gaGT is offline
i'm having the same problem...where are the IAC and MAF located, and what should be used for cleaning? just gumout carb & choke cleaner?? and Slade, what would a new IAC cost?
Old 08-21-2004, 10:37 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
isopropyl alchohol works great
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 10-17-2004, 01:18 PM
still happening, only worse
After all this time I'm still having this problem, only it is now getting worse. The car idles making this palpitation sound almost constantly now instead of intermittently, and it sounds like it will stall but it never stalls. The hesitation is definitely occurring at the same time as the stutter(palpitation) sound. Mechanic says he's checked the cat and it''s fine. Mechanic thinks it's an electrical problem and to take it to dealer. I don't have money to spend on diagnostics. Some people here suggested cleaning the IAC or mass airflow sensor. How can I do this and where are these parts located? If anyone has any other suggestions on what the problem could be, please post! Thank you.
Old 10-17-2004, 01:36 PM
One more thing I noticed is the car runs fine while driving, but going up any hills will always make the palpitation sound.
Old 10-18-2004, 05:26 PM
bdhiggins20 bdhiggins20 is offline
when they changed the plugs did they change the plug wires? sounds like plug wires to me...
Old 10-31-2004, 02:27 PM
Finally got this problem fixed after 6 frustrating months! Just in case anyone else has this problem...it was the coil cover. The car doesn't have spark plug wires but this instead?
Old 11-01-2004, 10:57 AM
Slade901's Avatar
Banned
Yeah, it's called Ignition Coil Housing. It's good to know that a malfunctioning Ignition Coil Housing causes that problem. On our vehicle, I've narrowed down the problem to the Ignition Coil Housing because I've only two sparks out of four.
