Old 07-08-2004, 08:09 PM
sschust sschust is offline
spark plug removal
I am changing the spark plugs on my 1999 4.3l chevy s10 pup. Does anyone know how to change spark plug on driver side that is located behind the steering coloumn
Old 07-08-2004, 10:18 PM
Philo Philo is offline
Re: spark plug removal
I have a '94 4.3. It is difficult. I used a sparkplug wrench with a hex fitting at the end that connects to the rachet. Rather than use the ratchet, I used a box end wrench on the sparkplug wrench. It still took half an hour to get the old plug out and the new one in. I did not care if I cracked the ceramic on the old one, but be careful when tightening the new one - it is very easy to crack when using this method.
Old 07-09-2004, 02:17 AM
atomicpulse's Avatar
atomicpulse atomicpulse is offline
I actually just changed mine, and what I did was just disconnect the steering column, which allows you to move it out of the way and change the sparks plugs very easy and quickly.
Old 07-09-2004, 01:34 PM
smokey041369 smokey041369 is offline
the easiest way to can them is use a swivel on the end of a long exstention
Old 07-11-2004, 10:09 AM
wehswarriorS-10 wehswarriorS-10 is offline
Send a message via ICQ to wehswarriorS-10
you can get to them from the fenderwell too i think
Old 07-13-2004, 01:48 PM
jdk2269 jdk2269 is offline
Send a message via AIM to jdk2269
We went in through the fenderwell on my 95 S10. its a pain but it allows for easier access.
Old 07-13-2004, 11:24 PM
www451oa www451oa is offline
I have a 94' v6 4.3 and I've found the Best and quickest way is to remove the front tires, and go through the fenderwell like JDK2269 metioned. Once you remove the tire, the spark plugs are right there, and very easy to get to, with plenty of room to work with.
Old 07-22-2004, 06:01 AM
Bookie1962 Bookie1962 is offline
I myself jack up the left side under the frame, turn the wheels to the right, and go through the inside fender well. You can get to the back 3 plugs with little to no problem. I also do this for the back plug on the passenger side, but i turn the wheels to the left. This might take a few minutes longer, but it is so much easier.
Old 02-20-2005, 11:32 AM
oldcrow oldcrow is offline
Could you give some details on how to get the steering column out of the way?
Old 02-20-2005, 02:30 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
With a couple of long extension and a swivel on the plug socket end get it from the wheel well.
Be patient and don't cross thread it!
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-20-2005, 06:36 PM
sector95 sector95 is offline
atomicpulse hit the nail on the head.... you *have* to disconnect the steering shaft..... had to do the same thing on my '93 4.3L. You can leave the shaft hooked up and try swivel adapters, but the chance of a cross thread are too great. It's not that hard to remove the shaft:
Up under the power brake motor is the connector; a single bolt/nut on a pinch clamp. Loosen the bolt and slip the shaft off; you will have to telescope the steering shaft into itself a bit to remove it from the connector.... a little WD40 might be required to loosen the connectors and the slip shaft.
A good Chilton's manual is a handy thing to have when your working on your truck. It will often answer your questions and give you a picture of how to do it.
Good luck...
Mike
Old 02-20-2005, 06:44 PM
BlazerLT's Avatar
AF -Advisor
No you don't HAVE to.
I did mine without doing that.
Old 02-20-2005, 07:04 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Easier to disconnect the intermediate shaft. SImply remove the 11mm bolt at the base, and the shaft telescopes into itself. It's keyes so it really only goes back on one way.
Old 02-20-2005, 07:43 PM
ALMB~Nova ALMB~Nova is offline
removing the steering shaft is not the best way to do this. have patience-go through the fender well. If you think these are hard to do, just try to change plugs on a V8 S10 with headers. ( Had to make a special box end wrench to do 4 of the plugs)
Old 02-20-2005, 07:45 PM
rlith's Avatar
Easier to just pull the bottom of the intermediate shaft... Kinda hard to mess that up.
