| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Well i think i know but im not sure what exactly is done when you port and polish the head? Also when you port the intake manifold what is done?
removes material from the head to increase air velocity and smooths out areas that impede air flow to increase overall performance of the motor.
power by efficiency |
Porting is resizing an opening to match it to the mating surface (increasing air velocity and volume...as Drift said.). Polishing is done to smooth the interior surfaces of the port to improve flow characteristics. Polishing also prevents hot spots.
Porting the intake manifold is the same as above. You are porting (or resizing) the manifold so that it matches the port on the throttle body and head. Same with the throttle body...you can port it (or buy one with a larger diameter to match the intake manifold). ONCE YOU MAKE CHANGES TO THE AMOUNT OF AIR THAT THE ENGINE IS TAKING IN...YOU MUST ALSO MAKE CHANGES DOWNSTREAM TO ACCOMODATE THE EXTRA AIR. (ie. adding a larger throttle body...you must also port the intake and in turn port the head to match...otherwise you will not get the most out of your modification.) 'Keep in mind, when you improve air flow, you must also calibrate the fuel flow to match or you're not going to go faster.'
![]() PraxisPerformanceAutoworks LLC High performance autoparts & accessories. ________________________ sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers _____________________________ PraxisForums...informative information ____________________________ PraxisRacing is sponsoring. click for more info. _____________________________ see PureHonda in its original colors--> |
praxis,Thanks for clearing theat up for me bro
