Old 07-08-2004, 07:31 PM
RSLaser RSLaser is offline
TBS question (1g mechaninc HELP!)
My car was actin up quite a bit, doin the whole surgin thing but then i check the throttle body sensor and the connector has 3 dff connections in it, the 1 to 4 was fine between 3.5-6.5 like it was supposed to be and when you twist the throttle linkage it raises the ohms like its supposed to, but the 2 to 4 had the voltmeter pegged. That means its not workin properly right?
Sorry its so confusing. thats the best way to describe it.
1991 Plymouth Laser RS
Only sat for a few years....
Old 07-08-2004, 10:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: TBS question (1g mechaninc HELP!)
thats the tps sensor
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-09-2004, 01:06 AM
EvoZero's Avatar
EvoZero EvoZero is offline
Re: Re: TBS question (1g mechaninc HELP!)
Shouldn't you be using the new cover sheet?
Old 07-09-2004, 09:30 AM
Re: Re: Re: TBS question (1g mechaninc HELP!)
wtf are you talking about newb?
-1stGenRocks-
Old 07-10-2004, 01:00 AM
ooops my bad its the throttle position sensor, im tryin to do this without a book, i used a friends for what igot so far.
