Old 07-08-2004, 05:03 PM
Bungee's Avatar
Bungee Bungee is offline
How to reset "Service Engine Soon" light
The Service Engine Soon light came on in my 2000 Silverado (100,000 miles).
I checked the gas cap for tightness, filled up with high octane gas, and poured Injection Cleaner in the tank.
I'm ready to take it into my mechanic, as the light remains on after 50 miles. But he says you need to reset the computer (after doing the work) for the light to go out.
Anyone kow how to do this?
Thanks in advance
Old 07-08-2004, 10:38 PM
Ryanj33 Ryanj33 is offline
Turn the key to auxilliary and press in the gas pedal three times all the way to the floor . You need to do it pretty fast for it to work.
Old 07-09-2004, 01:14 AM
internic internic is offline
Post resetting light
Pushing the gas pedal three times within five seconds is only to reset the Change Engine Oil light, I believe.
Old 07-09-2004, 04:23 AM
Ziggy1 Ziggy1 is offline
Re: How to reset "Service Engine Soon" light
If you take your truck into a chevy deler they can hook you truck to there computor to see what codes have made the light come on. Some times it will come on due to the fact it is time for service. But it also may be something starting to go bad in the truck. Any way they can reste your computor. I have had this done with no charge.
Old 07-09-2004, 12:11 PM
Bungee's Avatar
Re: resetting light
Right. I think I'll take it in to the dealer as advised, unless someone has another suggestions.
Thanks
Old 07-09-2004, 05:20 PM
LastOne LastOne is offline
Take your truck to AutoZone. They will read out the code and tell you what it means. If you ask them they will reset it also. Free of charge. I bought an AutoXray scanner finally and now can do it myself. Other chain parts houses should be able to do the same for you. Good luck
Old 07-10-2004, 10:35 PM
Bungee's Avatar
Re: How to reset
Very cool. Heading out now. Thanks
Old 07-11-2004, 07:56 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: How to reset
Thanks in advance
When thew SES light comes on, the PCM has seen a problem with an emission control componant and has set a code..clearing the code and turning off the light without diagnosising and repairing the cause will do nothing but mask the problem.
There are about 100 codes for emission control componants and about 30 for trans
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 07-13-2004, 06:04 AM
gtmud gtmud is offline
If your SES light is on, I agree with GMMERLIN, I'm not sure if you can do it on a 00' but on my 91, I can jumper point "A" & "B" on the diagnostic block located under the steering column, count the flashes then refer to my Haynes manual to match the code with a componant. This will save you the money of diagnostic charges at the dealer. IMPORTANT: After you replace the defective part, you need to clear the codes by disconnecting your negative battery for about 2 minutes. Good luck.
Old 07-13-2004, 05:31 PM
vnotaro vnotaro is offline
Re: How to reset
How do you like the AutoXray scanner? Have been looking for a scan tool for some time now. I've heard of AutoXray before but never run into anyone that has one. What did you pay, if you don't mind. There's a lot of them out there and I'm sure a lot of them are junk.
Old 07-14-2004, 11:10 AM
I bought the 6000 model on ebay. It was around 550.00 Excellent tool as it shows real time data as you drive! It is CAN complient for the new cars coming out after OBDII goes away.
Old 07-14-2004, 01:58 PM
Re: How to reset
Thanks for the info!
Old 07-14-2004, 03:32 PM
Chevy_girl00's Avatar
Chevy_girl00 Chevy_girl00 is offline
Send a message via MSN to Chevy_girl00
I guess i don't understand why you would want to reset the service engine soon light.... it obviously means that you need to take it in and get something checked, or something's wrong. And in that case, wouldn't the mechanics reset it...?? Sorry, it just doesn't make sense to me.
Old 07-14-2004, 07:12 PM
Re: Re: How to reset
If you have a scan tool, you can diagnose the problem and many times fix it yourself. Obviously, after the problem is fixed, you can reset the "service engine soon" light. There will come a time when your warranty is up and the dealer will charge big bucks to diagnose and fix your problem. Most of us would rather do it ourselves if we can after the warranty is up.
Old 07-14-2004, 08:10 PM
MuscleCrazed MuscleCrazed is offline
Yeah listen to the guys at autozone, they are all mechanics *rollseyes*
