Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-08-2004, 04:08 PM
joeyersak joeyersak is offline
Send a message via AIM to joeyersak Send a message via MSN to joeyersak Send a message via Yahoo to joeyersak
ignition lockup
does any1 no wut could cause the ignition on a z31 2 lockup? i tired jiggling the wheel that didn work and check the ignition fuses but i cant find anyhitn wrong
Old 07-08-2004, 09:44 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: ignition lockup
my z32 does that every once and a while. but i just wiggle my wheel and it unlocks. i woud just start wiggling anything and just try sliding the key in and out a few times.
ZedEx Crew Member #2
Old 07-09-2004, 02:20 AM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: Re: ignition lockup
Perv...
My old Z was REALLY bad about that...as the key gets older, the little peaks and vallies that make up the key and turn the tumblers in the ignition get worn down. On top of that, the key can start to twist a little from you trying to make it turn...be careful of this. Over time, the key will start to not work so great. I was pretty much the only person that could start my other Z because of this. If you move the key around while trying to turn it and turn the wheel off the steering lock, it'll be easier for you.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 07-09-2004, 02:46 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
well if it is an automatic. try moving the shifter back and forth. my key will not come out unless i pull back on the shifter a little bit. the locking mechanism for park is a worn. that is my guess. and u cant take the key out unless its in park
