Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-08-2004, 02:48 PM
skydog484 skydog484 is offline
Send a message via AIM to skydog484
Im doing a swap and dont know what tranny to use
I am putting a st185 in my 90 gts and i have no idea what i should use for a transmission. If i should keep the one that is in there or if the V6 camry trans will bolt right up to the engine.
Old 07-09-2004, 04:48 PM
skaterblader23 skaterblader23 is offline
im running a little slow today so i dont remember which engine the st185 is.....anyway if you use an all-trac engine(3S-GTE) then you have two good options.
1.) Find an all-wheel drive tranny and get a new rear axel to accomodate the AWD feature.
2.) Use a MR2 tranny....(yes i know it is RWD, but the engine was in the back so it will fit in perfectly to make a FWD celica Turbo)
Old 07-15-2004, 12:30 AM
theDRIFTER theDRIFTER is offline
Re: Im doing a swap and dont know what tranny to use
or you can use an 89 gts tranny that car had a non-turbo version of the same engine.
Old 07-15-2004, 11:33 PM
dynamictuner dynamictuner is offline
Send a message via AIM to dynamictuner Send a message via Yahoo to dynamictuner
If he uses the 86-89 GTS celica trans he needs to move the starter.. You could use your tranny just make sure to ask for a 5sfe clutch and 3SGTE pressure plate. ACT or Centerforce knows about this. Your clutch will do fine up to around 350hp then something might break.
Old 07-16-2004, 09:18 PM
Do what you like... but I've done this swap.
