Old 07-08-2004, 01:33 PM
bigmann245 bigmann245 is offline
1989 GT won't start
my 1989 ford mustang gt will not start. it would stall while in a turn and now it wont start at all. the fuel pump cut-off switch (inertia switch) is a little wierd. the reset button is very loose. when i press it, it will not stay in. is this the way it is supposed to be or is it bad? also where can i get one? the car cranks over fine but will not start.
Old 07-08-2004, 05:26 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
just get a new inertia switch, at a junkyard or a ford dealer, it doesn't matter too overly much as long as it's clean and it works. hell, doesn't even have to be clean.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 07-08-2004, 10:58 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
If the inertia switch does not stay in then yes you need a new one. A ford dealer would be the best bet, cause you never know if a junkyard one is ready to go or not. But hey if u get it cheap, whatever.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-16-2004, 03:56 PM
I finally found the problem. thanks to all who tried to help me. it ended up being a broken ground wire next to the starter. it was broken way down underneath all the wires that go to the starter and ground. once i repaired the wire the pumped primed and i was able to start the stang no problem. i decided to start chasing wires since im an aviation electrician and figured since i changed all the parts in the fuel and ignition systems it had to be a wire somewhere. it still is a good thing i changed all those parts anyway since the gt is an 89 and had a lot of old origional parts. i learned a lot from all this so thanks to all who gave their advice. take care all.
