Old 07-08-2004, 01:27 PM
rmjcott rmjcott is offline
rmjcott. how to test a relay?
Got the relays out of the 92 plymouth, now i need to know how to test them . There are 4 in this bank.. please advise.
1-4557540-1052
3-4557539-1042 HELP>>>>>>>
Old 07-08-2004, 07:19 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: rmjcott. how to test a relay?
Find a 12 volt source with ground. Place a positive lead on the positive and touch the negative to the other terminal/terminals, if it clicks or closes it is working if not it is bad.
Old 07-08-2004, 11:27 PM
Hi.
The relay is a closed unit and when i put 12 volts to it there is no click and I can't see if it is closing.
Now What?
Old 07-09-2004, 05:40 AM
Pontiac Guy
Connect a test light to the terminal that the relay is supposed to supply voltage to. Apply the voltage as before, if the light comes on then the relay is good. If it is on when you connect it and the light goes off it should be good as well. If no light then the relay is probably bad and needs replaced. (Don't forget to ground the test light or it won't work.)
