Old 07-08-2004, 01:23 PM
Aasgard Aasgard is offline
Fuel Tank Noise
We recently had our fuel pump replaced on a 98 Tahoe. Now, after it has been driven, is turned off, sits for about 3-5 minutes, the gas tank makes a noise like it is expanding or contracting - a "thunk" noise.
Any ideas out there. Is the gas cap bad, allowing air in?
Thanx.
Old 07-09-2004, 10:19 AM
debh1123 debh1123 is offline
Re: Fuel Tank Noise
I have a 2000 Tahoe and it is doing the exact same thing....has ever since I bought it! I am VERY interested to know the cause/solution. You are the first one I've seen with this problem too.
Thanx.
Old 07-15-2004, 10:30 AM
seashift seashift is offline
I have a 99, and have had this problem. At 30,000 miles I had it in the dealer for this problem, and they said they could'nt find a problem. That was 60,000 miles ago. It seems to have dimminished.
Old 07-21-2004, 09:59 AM
kelnol kelnol is offline
Re: Fuel Tank Noise
OMG! I thought I was going nuts! I seem to be the only one that ever heres it make the noise. I'd be very interested to here what is causing this.
Old 07-21-2004, 06:05 PM
JD68 JD68 is offline
Re: Fuel Tank Noise
one of the tahoe issue classics, everyone has this problem it seems, the pump is in-tank and when the tank becomes more and more empty the space allows for the pump to make more noise, modern engines like the vortec have to sustain fuel pressure around 60 psi so pumps have to work harder, noise means operation, be worried when you dont hear your pump ;P
Old 07-21-2004, 09:14 PM
Accord_boy619 Accord_boy619 is offline
I have a 97 n I hear a hmmmmmmin sound, its like its whinin. is that good or bad?
Old 08-12-2004, 05:10 PM
Tagahoe's Avatar
Tagahoe Tagahoe is offline
Re: Fuel Tank Noise
I have that same problem, kinda like a wheezing sound. It even stays on for about 2 seconds after turning off the vehicle. I was going to replace my fuel pump. I thought once it starts making noise, that means its fixing to go out.
Old 09-01-2004, 04:39 PM
Tagahoe's Avatar
Yup, that noise is a bad sign. My fuel pump just went out on me, and now its going to cost between 259-279. Good thing I have under quarter of a tank.
Old 09-04-2004, 01:23 AM
You doin it your self? Is that the price of the pump?
97 Tahoe 2dr- raise = http://www.cardomain.com/id/tahoe_boy619
98 Accord 4dr-droped = http://www.cardomain.com/id/accord_boy619
Old 09-09-2004, 04:33 PM
Tagahoe's Avatar
yeah, fixing to install it now. I found one at pep boys for $169, came out around $218. I have the hoses disconnected, skid plate off, and the tank loose. Im fixing to go drop it right now. im going to use a jack to help hold it up.
