Old 07-08-2004, 11:15 AM
harve harve is offline
1995 gmc safari transmission swap
Will the tranny from a 1990 safari AWD work in a 1995 AWD? or can it be made to work? any info on which will work or others that will. How do I find out what the tranny is in either vehicle? THanks
Old 07-08-2004, 08:57 PM
Jeremy-WI Jeremy-WI is offline
Re: 1995 gmc safari transmission swap
NO, the 95 has an electronic tranny and I'm not real sure what other years will work as there are quite a few changes done to these trannies. I would think a 94 - 96 would work out of any rear wheel drive GM, but you might have to change tailshafts
Old 07-17-2004, 08:05 PM
Maifirehawk Maifirehawk is offline
My reply might be too late but here you go,
Jeremy is right, GM changed this unit in 93.
92 was the last year that is hydralicly shift, 93-94 all electronic Non PWM, 95-up electronic with PWM and GM went back to Non PWM again in 99-00,
This mean the PCM program differently to acomandate these changes, so make you put in what you pull out.
Mai
