Old 07-08-2004, 12:04 AM
pelado's Avatar
pelado pelado is offline
Send a message via AIM to pelado Send a message via Yahoo to pelado
Arrow Thunderbird 1992
Hello Guys all good? Gained a Ford Thunderbird 1992 cs of the Revell of a friend mine I liked it very I mounted the engine already more I I would like to know if valley the penalty to open the cover of the door luggage and to make the door luggage of it as in 1:1 I would like to place In inside and the some Subs as I I could there open the back cover? e as to place the hinges?
Thankss
Old 07-08-2004, 12:12 AM
351Cougar's Avatar
351Cougar 351Cougar is offline
Unhappy
huh??
my name is Justin feel free to use it
69 Cougar 351W fmx 3.00s 17x8 06 bullits... sold
92 Camaro RS 305 tbi T-5 purple haze metallic (92 color only 1 of 8,556) - custom ram air, lowered
88 AE92 4afe powered sedan.. got it for $250
Old 07-08-2004, 09:07 AM
tonioseven's Avatar
Re: Thunderbird 1992
It would be easy to do; just be careful when cutting the trunk open and make sure you have some styrene sheets to build up the trunk area. I've started a similar project with a '92 Revell Mercury Cougar and the cars ar very similar. I don't have current pictures but you should have no problems if you take your time.
Old 07-08-2004, 03:59 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
i could help you, but.. uh..im guesiing English isnt your main language. If you want, i can take some refernce pictures of the trunk and hinges. (look down in my sig..)
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
