Old 07-07-2004, 06:19 PM
OverrRyde OverrRyde is offline
Send a message via ICQ to OverrRyde Send a message via MSN to OverrRyde
Tips And Tricks to cleaning!
Hey guys, little ? here...
This friday i have a full day off (yahoo!!) and i was thinking of cleaning my engine...
My question is; can i take out part safely to clean them by hand?
and what would u suggest about poducts to use to get'em them as clean as possible?
Thanks!
Old 07-07-2004, 06:56 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Simple Green works pertty good.After you finish cleaning all the metal surfaces, spray tire shine over the engine, run it for a few min, open the hood back up and all the hoses and lines will look brand new.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 07-07-2004, 07:22 PM
BullShifter's Avatar
Re: Tips And Tricks to cleaning!
Use any degreaser or engine cleaner & follow directions. Pressure washer is better than a normal hose since the PW uses 50% less water & the obvious PRESSURE. NEVER use tire shine under the hood because it could cause a fire, ruin sensors, etc. Your best off using WATER BASED interior dressing for under hood purposes, not that tire shine won't work it's just the wrong chemical mix to be used around heat & sensitive electronics.
I'm sure if you search this site you will come up with numerous engine cleaning how-to's. I know I've posted engine cleaning tips MANY times. There is a detailing section - http://www.automotiveforums.com/vbul...lay.php?f=1070
If you want the engine compartment to be as clean as possible then pro steam cleaning is the only way to go.
