Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 07-07-2004, 03:45 PM
flivesay flivesay is offline
Unhappy fuel pump code?
96 jimmy 4.3 w engine
Will a fuel pump with reduced flow/pressure set a p-code? I am having trouble diagnosing a loss of power when depressing the throttle--
Old 07-22-2004, 11:42 AM
jeffstone1960 jeffstone1960 is offline
Re: fuel pump code?
I'm experiencing the same problem and am pretty perplexed. At first it just hesitated intermittently. Now I can barely get the truck moving. The only code I show is 13 which points to a faulty circuit on the O2 sensor. I've checked the wiring on the O2 sensor, replaced it, and still get the same error. I'm checking all the grounds on the wiring now. I think this may be unrelated to my fuel problem anyway.
I called the parts place. They said if the pump was out the truck just wouldnt get gas. They suggest I change the fuel pump relay. I have a 90 s15 jimmy.
Hope some of this information may help you.
